Anyone replaced their Button head grease fittings with Zerks Why or Why not?
2 years 3 months ago #239598 by brian18a
A Alemite volume compressor produces 500 psi max. A Alemite battery powered grease gun will produce 10,000 psi max. So one sees why a grease gun can easlily destroy seals.
The following user(s) said Thank You: G2D2
2 years 3 months ago #239609 by Deas Plant.
Hi, G2D2.
They're YOUR track rollers AND you HAVE been told about the perils of using a normal grease gun to fill them - an electric or air powered grease gun is WAY worse - so if you want to use your electric grease gun on them, PLEEEZ, feel free.
BUTTTTTTT, if you come back complaining about blown seals in your rollers and idlers, DON'T be surprised to be greeted by a chorus of, "We told you so."
For quite a few of the people on this BB, it AIN'T quite their first rodeo.
The following user(s) said Thank You: kracked1, G2D2
2 years 3 months ago #239613 by trainzkid88
cotton picker grease or corn header grease. both are ngli 00. any regional fuel distributor should carry the grease or order it in for you not a problem. go to any john deere or caseIH dealer and they will have it in stock or order it in. there are few other greases that are ngli00 viscosity too but picker grease is readily available in all cotton and grain growing countries.
oh and DONT use a cordless grease gun unless you make a relief adapter like i said you will blow the seals at least with a manual gun you have a chance to feel when its full.
from memory the pressure is no more than 12psi i read that in another topic cant remember which one.
yes cat use the larger 7/8th button head fittings that are 3/8th NPT thread remember that all the threads one these old girls are SAE threads all fittings are NPT
2 years 3 months ago #239623 by TomTrack44
I was able to purchase a good bucket Alamite grease gun for $20.00 last year on Facebook Marketplace. The guy had 5 of them and would have sloe all 5 for $20 ea, I only needed one so that is all I bought. I remember as a kid back in the 50's I had the job of greasing the D4's rollers, I remember Dad instructing me to only pump in grease until you feel resistance, you do not want to blow the seal, cause then I have to take the track apart and pull the roller and replace the seal. It is very hard work and takes a long time so you be careful. I always was. We had a disk plow that had button head fittings too, same advice, do not over pressure, you can feel a sudden increase in resistance, STOP, so you do not blow the seal. Sound advice.
2 years 3 months ago #239640 by G2D2
Thank you all ! I will look for a old hand pumper for the grease! A pressure relief valve would be nice but On a quick search I came up with mixed results. However if I take the bolt out on the other side of the rollers the grease will just ooze out when it’s full?! I’m a noob when it comes the the tracks and I did order a operation and service manual yet to arrive. Thank you for all the Sage advice!
2 years 3 months ago - 2 years 3 months ago #239643 by Deas Plant.
Hi, G2D2.
As I understand it, the low pressure volume gun intended for the job has enough pressure to push any air out of the roller past the seals without damaging the seals themselves. If you pull the bolt/plug out of the other side, you are NOT gonna get the full fill.
There were some pretty smart cookies 'figgered' all this out close to 100 years ago and it has worked for all of that time since. Is there any need to 're-invent the wheel'?????????
Last edit: 2 years 3 months ago by Deas Plant.. Reason: added info.
The following user(s) said Thank You: TomTrack44
2 years 3 months ago #239661 by trainzkid88
relief fittings are available but vary greatly in price. i found a full listing in the alemite catalog but didnt find the rating i wanted for sale online and what i could get varied greatly in price one place to the next.
2 years 3 months ago #239724 by G2D2
This is what I found
www.amazon.com/Alemite-7118-1-Alemite-71...strial%2C170&sr=1-19
It's for loading grease guns but produces 500 lbs Probably hose it up and throw on an adapter expensive but...
2 years 3 months ago #239728 by D4Jim
That is much better than a regular grease gun but think about the gizmo on top, moving it around, keeping the lid on, making a handle etc. Why not find a used volume pump and be done with it? It appears you are trying to make an easily solvable problem into a difficult one.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
2 years 3 months ago #239730 by Deas Plant.
Hi, G2D2.
This is the gadget PURPOSE BUILT for the job: 777parts.net/caterpillar/ie/UE0325630419.html
Because they are purpose built. they are the best tool for the job. Now all you need to do is find one. That site may even have them for sale. I don't know as I had no need to find out.
Time to create page: 0.214 seconds
