Frozen chains
2 years 5 months ago #238403 by Rickoshay
Frozen chains was created by Rickoshay
I'm looking at an early 60's D6 for sale. Other than the rust, the tracks are like new(no wear on grousers and bushings) which may have led to it's problem: it won't move, possibly from sitting too long. I've talked to several knowledgeable folks who've suggested using a penetrant to loosen the pins/links to just salvaging the shoes/pads and getting replacement chains. I don't know if a press is required to split the track on tractor of this size. If I pass, the tractor will probably just sit and rust away.
2 years 5 months ago #238404 by seiscat
Replied by seiscat on topic Frozen chains
You say early '60s, that was when there was two D6 tractors available the D6B and D6C. There are several methods to loosen the tracks that will work on both machines. Please provide the serial number and if possible pictures of the tractor.
Craig
2 years 5 months ago #238406 by Rickoshay
Replied by Rickoshay on topic Frozen chains
It's a "B". With both steering clutch levers pulled back, one track moved when the flywheel clutch (aka: main) lever was eased back. I have pictures on my IPhone but I don't know how to post them on this site.
2 years 5 months ago #238408 by bursitis
Replied by bursitis on topic Frozen chains
just use water to loosen the rust.
2 years 5 months ago #238409 by dpendzic
Replied by dpendzic on topic Frozen chains
yes just park it in a wet area with the bottom of the tracks in water and let it set a while
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
2 years 5 months ago #238413 by PhilC
Replied by PhilC on topic Frozen chains
Are you getting any movement of the sprocket on the side that won't move? If there is no movement of the sprocket then the problem might be deeper.
If the sprocket is moving slightly inside the chain you might be able to get the chain to free up by going back and forth repeatedly. Maybe throw some old diesel or penetrating oil (or water) on the links.
2 years 5 months ago #238415 by Rickoshay
There's not a hint of movement in one track, just the straining of the engine as the main clutch lever is slightly eased back. As you mentioned, perhaps the problem is deeper than just the tracks.
2 years 5 months ago #238416 by neil
Replied by neil on topic Frozen chains
If the sprocket doesn't move, your brakes might be seized on on that side, in which case you can slacken them and try to break them loose if you have access to any of the components. I'm not familiar with the B model brakes but if it's a band, it should be fairly straightforward to get in there with a poker/breaker to break it free
2 years 5 months ago #238417 by Rickoshay
I have an old Caterpillar D6B "Operation and Maintenance Instructions" booklet coming in from Ebay that might tell me something about the brake system. This tractor also has hydraulic steering boosters: I checked the reservoir under the seat and I didn't see any fluid.
2 years 5 months ago #238419 by seiscat
You did well ordering the O.A.M.I. book it details how to adjust the brakes. Look and see if the right brake pedal is lower than the left brake pedal. If the right petal is lower the parking brake is engaged, to release it press the right brake petal and release the brake locking lever. The locking lever is on the right and back from the brake petal.
You should be able to post pics soon.
I have a spare Service Manual for the D6B that I will sell reasonable.
Craig
