212 grader serial #1
2 years 5 months ago #238326 by trainzkid88
Replied by trainzkid88 on topic 212 grader serial #1
WayneRKing post=238301 userid=4152Hi Dan
For interest sake some pictures of the Honda setup. I know its not the correct set up but some thing like that could
keep a machine going. Here in South Africa parts and parts tractors are scarce. Freight from USA is more than the part.
Wayne
Stutterheim South Africa
If anyone is interested I have found a way to bypass the Magneto coil for a horizontal style pony motor (may also work on vertical style). It can run an automotive 6v or 12v coil (with or with out resistor). If there is enough interest I will make a video.
thats fairly common on stationary engines. when the mag windings die. its also common with low tension ignitions that had a seperate coil and dynamo to replace it with a 8 volt coil from a car.(these are the ones with the ceramic resistor block on the side found on many japanese cars in the 70s/80s)
Time to create page: 0.128 seconds
