955 12A Steering Levers Stuck
Thank you received: 24
2 years 5 months ago #238269
by d9gdon
So I let my 955 12A track loader set out for about a year and a half and when i started it, the steering levers are frozen up. They are free on the cross shaft but they won't actuate the steering clutches.
I don't know if the clutches are stuck in the drum or what.
Fat Dan
Thank you received: 820
2 years 5 months ago #238270
More than likely it's the linkage pivot bearings that are froze up, the ones you can't get to to lube although you can access the upper ones by removing the cover.
Fat Dan
2 years 5 months ago #238271
by d9gdon
I think I'll take off the top cover tomorrow and see what's going on in there...I have a parts book coming from Ebay. I guess the upper ones are lubed by zerks that I see on top of the cover.
My danged clutch lever is seized up on the cross bar too...I can heat it up and get it to working but 5 minutes later it's seized again. It's not turning the cross shaft, the brake pedals are working fine.
2 years 5 months ago #238273
If it has zerks in the cover someone has added them. Problem is there is an air gap between the cover and the pivot bearing so unless there is some type of coupling (big fat 0-ring maybe) the grease would not penetrate the bearing.
Fat Dan
Thank you received: 276
2 years 5 months ago #238278
by rax200
Hi d9gdon,
here is a couple of the steering clutch cranks in side my 7U which shoul be the same, they where stuck solid too. When I pulled them apart they where rusted solid.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Fat Dan
2 years 5 months ago #238283
by d9gdon
Yes OM, I see the grease zerks are not on the cover but mounted ahead of the cover.
I'm going to pull that cover and see if I can get some penetrant in there...and go from there.
Thanks to you and Daryl.
Fat Dan
2 years 5 months ago #238284
Unfortunately, under the right weather conditions those compartments can be real rain makers as far as condensation goes.
Fat Dan
2 years 5 months ago #238286
by d9gdon
Well, I get to pull the top cover it looks like...fantastic.
I guess I'll rebuild the clutches while I'm in there and check the bevel gear bearings, they've always been suspect.
But first I'll need to spend 40-50 hours removing the loader assembly.
But I'll need to rebuild this 1586 IH tractor engine before I can make enough room in my shop.
Fat Dan
2 years 5 months ago #238288
Apparently if you strip everything flat you can get the cover out of there without removing the loader.
Fat Dan
Time to create page: 0.182 seconds
