D315 Engine info wanted
2 years 6 months ago #238141 by side-seat
Can anybody tell me the year or specs for 9S13218
My serial number book has just 9S as a marine engine.
2 years 6 months ago #238143 by Old Magnet
Replied by Old Magnet on topic D315 Engine info wanted
Rack setting bible has the 9S5001-up as Industrial, Marine and Gen set Engines
Specs vary according to full load engine rpm.One example is 54 hp continuous at 1800 rpm.
Close as I can get is 1953-1958 for late s/n engines.
Unit was replaced by 48Bxxxx in 1959
2 years 6 months ago #238144 by side-seat
Replied by side-seat on topic D315 Engine info wanted
Thanks OM .
This was out of most likely a 15B Bucyrus Erie.
Were going to do a transplant into our D47U I posted back a couple months ago the we dragged in. Engine took in a good bit of water sitting uncovered out in the woods. I figure it'll be much easier just swapping out parts from the original onto the power unit instead of finding a better head and put in liners. A couple jugs were really pitted bad beyond just running the ball hone in to clean up.
2 years 6 months ago #238147 by Old Magnet
That will be a balancer engine with later heads that can accomodate glow plug chambers and direct electric start. It will not have the front and rear scavenge plumbing for the oil pump.
2 years 6 months ago #238150 by Fat Dan
Replied by Fat Dan on topic D315 Engine info wanted
Well I'd say that should work with little medications here and there. Please keep us informed
ACMOC Member
Time to create page: 0.182 seconds
