933G oil filter
2 years 6 months ago #237902 by Broo1874
933G oil filter was created by Broo1874
Just bought last year so this is my first oil change. My manual says the oil filter is T20646. I can’t find that part number online. The local dealer wants a serial number or they won’t help me. I have tried reading it off the block but can’t make it out. Can anyone help me with a part number and place to order one? Thank you in advance for your help.
2 years 6 months ago - 2 years 6 months ago #237903 by Fat Dan
Replied by Fat Dan on topic 933G oil filter
A second S/N should be found on rear of transmission case, top left,
ACMOC Member
Last edit: 2 years 6 months ago by Fat Dan. Reason: Clarity
The following user(s) said Thank You: Broo1874
2 years 6 months ago - 2 years 6 months ago #237904 by Old Magnet
Replied by Old Magnet on topic 933G oil filter
933G model runs s/n 42A5918 to 42A9202
Original oil filter part # is 7M3800 = 1R0659 current Cat number or Wix 51161
Last edit: 2 years 6 months ago by Old Magnet.
The following user(s) said Thank You: Buddy, Fat Dan, Broo1874
2 years 6 months ago #237905 by Fat Dan
I've been looking and found the 933"C" 955C, 955E used a Cat 9F6700 p/n for replaceable filter
WIX
Product Specifications
Part Number: 51161
UPC Number: 765809511613
Style: Cartridge Lube Metal Canister Filter
Service: Lube/Hydraulic
Type: Full Flow
Media: Enhanced Cellulose
Height: 9.277 (236)*
Outer Diameter: 3.968 (101)*
Inside Diameter: 1.635 (42)*
Beta Ratio: 2/20=17/33
Max Flow Rate: 18 GPM
Nominal Micron Rating: 32
( )* denotes metric
Gasket Diameters
Number O.D. I.D. Thk.
15449 Packed 4.815 (122)* 4.585 (116)* 0.125 (3)*
15286 Packed 4.79 (122)* 4.63 (118)* 0.125 (3)*
15108 8 4.458 (113)* 4.25 (108)* 0.125 (3)*
Principle Application: Autocar, Bay City Shovel, Caterpillar, Gardner-Denver, Koehring, Komatsu
ACMOC Member
2 years 6 months ago #237906 by Fat Dan
Ya beat me to it OM 😁👍
Quick draw McGraw..😁
ACMOC Member
2 years 6 months ago #237908 by juiceman
Replied by juiceman on topic 933G oil filter
Fat Dan: You have to be fast on your feet, OM does not let the moss grow under his hat! Thanks for BOTH of you for assisting the original poster. JM
Time to create page: 0.156 seconds
