D5 98J information needed
2 years 6 months ago #237637 by bursitis
what would be the year manufactured Horsepower and engine type of a D5 98J in the 600 serial number range?  what would the transmission group 8S2154 spec be?  Thanks
2 years 6 months ago #237642 by Mschwartz
Replied by Mschwartz on topic D5 98J information needed
Hello, 600 serial number I think will be 1969 or ‘70. Engine should be a D333C, about 500 tractors before the 3306. Transmission will be a 6 speed version, geared for ag work. Is your engine turboed? Horsepower ranges from 120-200 around here, just depends on who has been working on it. We need pictures. aMike
2 years 6 months ago #237653 by bursitis
Replied by bursitis on topic D5 98J information needed
Thanks Mike---- yes it is an ag machine non turbo i think stated as 105 hp maybe a typo should be 150? or would the turbo be required for 150 hp? was there internal differences in the turbo engines different from the non turbo? or did they just add a turbo and adjust the fuel?
2 years 6 months ago - 2 years 6 months ago #237657 by Old Magnet
By my rack setting charts the 98J1-1133 uses The D333C engine non-turbo @ 120 hp. Same for the later D5B 3306, again non-turbo.
Transmission 8S2154 is a six speed, close ratio sliding gear type, same as used in the later D5B.
The transmission speeds are:
Forward
First 2.5 mph, second 3.0, third 3.5, fourth 4.0, fifth 4.6, sixth 5.6
Reverse
First 3.2, second 3.8, third 4.6, fourth 5.3
Turbo engines will have oil cooling jets for piston cooling.
Last edit: 2 years 6 months ago by Old Magnet.
The following user(s) said Thank You: bursitis, Fat Dan
2 years 6 months ago #237658 by bursitis
Thank You Magnet. so the D333C engine had two different blocks? one for non turbo and another for the turbo application? or could the piston cooling jets be added? was it common for a turbo to be added to these tractors configured like this?
2 years 6 months ago #237660 by Old Magnet
Cooling jets can be added, same block. The Special Application units did not originally come with turbo. but I guess it was fairly common to hot rod these units by adding a turbo. Certainly were other turbo versions in either the D333C or 3306 engines.
The following user(s) said Thank You: Fat Dan, Busso20
2 years 6 months ago #237780 by bursitis
does anyone have a link to the Nebraska test on the Caterpillar D5?
2 years 6 months ago #237781 by Ray54
Replied by Ray54 on topic D5 98J information needed
I got there very easy with google but the very quick look the last steel track machines I saw was a 1960 test. So no D5. But I only just tried once, but showed gas Cats and early stuff to 1960, then Challengers.
2 years 6 months ago #237918 by bursitis
anyone have the performance handbook information on the D5 98J 600 serial number range non turbo six speed SA tractor? i am interested in the drawbar pull in the gears?
2 years 6 months ago #237925 by Rome K/G
Replied by Rome K/G on topic D5 98J information needed
Found this,
Time to create page: 0.208 seconds
