Glow Plugs 101
Glow Plugs 101
Thank you received: 90
2 years 7 months ago #237466
by kittyman1
-is it necessary to replace glow plugs before they fail? as routine maintenance?
-do they have a lifespan? depending on use, number of starts? or just randomly fail?
-best before date? etc..
-if they have resistance measured with an ohmmeter, is that good enough? or should it meet a certain level?
-just wondering..
Thank you received: 663
2 years 7 months ago #237469
-just wondering..
Probably depends on your definition of necessary. I haven't seen any service manuals for any of the brands I've been into that talk about pre-emptively replacing glowplugs that still work. That said, if you "have the hood off", sometimes it's convenient to replace them all if one or two fail. I've had "random" glowplug failures, some after just a couple of years, and some after decades. Manufacturers often specify the acceptable resistance range for glowplugs
Thank you received: 820
2 years 7 months ago #237473
Typical resistance is 0.1 to 6 ohms but may still be good up to 11 ohms.
Kind of a random failure situation.
Thank you received: 999
2 years 7 months ago #237477
by Rome K/G
We always replaced them when reconditioning the head or around 10-12,000 service hours. We would inspect them at every 2000 hrs when adjusting valve tappet clearance.
Thank you received: 789
2 years 7 months ago #237486
a point to remember when checking the resistance, it should be read quickly ie a few seconds not half a minute. as resistance changes with temperature. also you dont want to burn out your multimeter. also buy quality units they last better. a light dab of grease or copper anti-seize on the thread will aid install and future replacement.
74A6C
2 years 7 months ago - 2 years 7 months ago #237487
by Rome K/G
There is an inch lb torque rating for glow plugs also, check in your engine service manual. 120+-24 INCH lbs for plugs on 3304,6 engines
Last edit: 2 years 7 months ago by
Rome K/G.
Thank you received: 30
2 years 7 months ago #237492
by 74A6C
My experience with glow plugs has been more extensive and expensive with Ford 7.3 IDI engines than "cold blooded Cat motors" as my Pap would call them, but I expect it's all similar. An engine will crank fine with them until it doesn't. Then one or all may be foul. Good steady voltage and clean tight connections are never a bad thing. And good quality replacements are sometimes a bargain at twice the price. Anyone who has been lucky enough to wiggle a Autocraft, Beru, insert generic part name here plug with a swollen tip out of those old IDI engines will probably argree with me. Also, some of the better manufacturers will give you resistance specs that their parts should fit.
2 years 7 months ago #237493
by 74A6C
But, as far as prevention of the problem goes, I reckon if you're dealing with a tired engine with more hours than compression or suspect fuel issues, not within your engine but within the cetane in the tank it's probably not a bad idea to add them to the maintenance list. We've done that a time or two on Pap's ol F250. And more recently I've watched the way the machines on the job have cranked on our sometimes questionable fuel. All different brands and different "Tiers" as they like to label them. It will certainly make you wonder.
Thank you received: 121
2 years 7 months ago #237501
by PhilC
Never heard of burning out a multimeter checking resistance for too long. You will do damage if you test resistance in a powered circuit. Most multimeters only put a small voltage through the circuit to test resistance and it shouldn't be enough to cause a glow plug to even get hot.
In the past I have connected alligator clips to my multimeter test leads and left them connected checking resistance for up to an hour with no side effects.
Agree with the comment about a quality meter though. I learned that in Auto TAFE and only use Fluke.
In regards to the thread questions; personally I think you would be throwing away perfectly good glow plugs if you replace them periodically. If you have an amp meter installed you can then tell when they are not working.
Glow Plugs 101
Time to create page: 0.193 seconds
