D6 8U year and part numbers
2 years 7 months ago #237107 by seiscat
Replied by seiscat on topic D6 8U year and part numbers
I found a nice D6 8U parts book on ebay if you are interested:
www.ebay.com/itm/383931319635?hash=item5...3:g:mUMAAOSwjzpgGGHT
Craig
2 years 7 months ago #237108 by dylangw228
Bought it should be here next week. Thanks
2 years 7 months ago #237109 by bursitis
you can run a segmented fan belt in a pinch. i had one i put on just to get me back to the shop and replaced it 10 years later.... with another one.
2 years 7 months ago #237112 by dylangw228
Good idea at least I would have a spare until I get a new one.
2 years 7 months ago #237114 by trainzkid88
thats the parker racor style ive used those too. easier to get them to seal than the delphi style which are a bit finicky due to multiple seals and parts.
2 years 7 months ago #237115 by trainzkid88
as another suggested segment belting is ideal as you can make belts of any length. it can also work out cheaper than having to order in a special belt. some machines actually use it from factory. as it is sold by the roll or by the meter and why carry 10 different size belts when you just buy 2 or 3 different roll of belting.
also as the belt stretches you can simply remove a segment to adjust the belt and no need to unbolt things just to change a belt simply back off the adjuster & split the belt to fit another. any good bearing or industrial supplies joint will have segment belting
2 years 7 months ago #237121 by dylangw228
I will definitely give the segmented belts a try.
2 years 7 months ago #237150 by seiscat
While I was looking on ebay I also found a Operation and Maintenance Instructions Book. These are very helpful and will save you time and money:
www.ebay.com/itm/334320782344?epid=15510...8:g:Qf8AAOSwLpZiATvB
The Serviceman's Reference Guide (Service Manual) is good to have also:
www.ebay.com/itm/334298850172?epid=15510...c:g:IL0AAOSwpzJh6bKI
or
www.ebay.com/itm/255480135157
Craig
2 years 7 months ago #237157 by dylangw228
Thanks Craig I'll add that to my list of things to order.
2 years 7 months ago #237184 by 74A6C
Replied by 74A6C on topic D6 8U year and part numbers
I'll second what was previously mentioned about supplying the Cat parts counter help with an already sourced p.n. When I started doing that my results took a huge change for the better. Although, I did get one good laugh one time watching the parts man have to dust off the folder of microfiche film, clear off a place on the counter, and plug the microfiche reader in to power to find what I was needing. All I could say was sorry fellas, my D6 isn't a new 6T. As far as fuel filtration goes, in my opinion, there are never enought until they're all needing changed at once.
