Cat thirty serial# tag
2 years 7 months ago #237060 by SoCalCatMan
 I have some serial # tags for a cat thirty (S 6348) that are pretty tarnished. They’re still readable but I’d like to shine them up. Anyone know of a safe way to do this? I don’t want to damage these tags, as they are the 2nd to last ones in 1927 (S 6349 being the last). Any help is appreciated! Thanks
2 years 7 months ago #237061 by ironman3406
Replied by ironman3406 on topic Cat thirty serial# tag
There is a company that I follow on Instagram that I think will be able to help you with this. They are called Von Industrial, the specialize in remaking old tags like this and they do absolutely amazing work. They will even stamp in the original serial number. Check them out: www.vonindustrial.com  or follow them on Instagram @kingtutley
I attached a couple samples as well of the workman ship that they have.  It really is great work in my opinion.
Nathan Duncan
2 years 7 months ago #237066 by SoCalCatMan
Replied by SoCalCatMan on topic Cat thirty serial# tag
Cool! They look like really good recreations. I’ll check them out!
2 years 7 months ago #237067 by Skinner
Replied by Skinner on topic Cat thirty serial# tag
Try cleaning it with white vinegar you may need to soak it.
The following user(s) said Thank You: ChrisRoyd2
2 years 7 months ago #237072 by trainzkid88
Replied by trainzkid88 on topic Cat thirty serial# tag
white vinegar works well but takes time. you could also use brasso or autosol the secret is use 2 rags one to apply one to remove. if you use vinegar you need to passivate it after wards so id doesnt flash corrode. bicarb soda will work for that and then spray with a clear sealer or lacquer.
2 years 7 months ago #237088 by SoCalCatMan
Thanks! I’ll try using brasso. Vinegar might cut through better but Ill use that on some other tags that I don’t mind experimenting on. I also have some tags for our high ten that are in roughly the same shape. If I remember, I’ll send pictures when they’re all shined up.
