D6b info
2 years 8 months ago #236729 by Mr Adams
D6b info was created by Mr Adams
Hello
New member here
I have just purchased a D6b not running was told there was engine damage bottom end
Iam looking for information on the machine
Year, type of engine
Serial number 44a10066
Thx
2 years 8 months ago - 2 years 8 months ago #236743 by Old Magnet
Replied by Old Magnet on topic D6b info
1965 wide gauge model with D333a engine (4-1/2" bore)
Total D6B 44Axxxx units produced = 1,3071
Last edit: 2 years 8 months ago by Old Magnet.
2 years 8 months ago #236744 by Mr Adams
Replied by Mr Adams on topic D6b info
Thx
Should I look into rebuilding the d333a
Or re power the machine I’ve got access too old d6 motors but thay have the pony how would I find out what a good swap motor would be and bolt up ?
2 years 8 months ago #236745 by Rome K/G
Replied by Rome K/G on topic D6b info
Uh....NO, rebuild the 333, parts are available.
2 years 8 months ago #236784 by trainzkid88
Replied by trainzkid88 on topic D6b info
your local cat dealer should have most parts available. some bits like bearings, seals and rings are also available after-market. you just need a parts book to get the appropriate part numbers.
2 years 8 months ago #236791 by seiscat
Replied by seiscat on topic D6b info
Florin Tractor 1-800-223-9916 can supply the parts for a rebuild. Your D6B is not a good candidate for a re-power because it uses a hydraulic pump that is gear-driven mounted on the timing cover of the 333.
I'm in the process of overhauling my D6B 44A engine and the hydraulic pump. The hydraulic pump is not available from any source. Florin Tractor was finally able to locate the parts to rebuild my pump but just the parts was over $1,000.00 so take care of that pump!
I'm sorry to be the bearer of bad news but a D6B with a bad engine is not a good way to get a 'dozer on the cheap!
Craig
2 years 8 months ago #236813 by robclay
Replied by robclay on topic D6b info
I'm no expert but I'd think you'd be able move your battery starter and delete the pony motor? Unless those are different engines, like a D318??
2 years 8 months ago - 2 years 8 months ago #236824 by Fat Dan
Replied by Fat Dan on topic D6b info
1965 should be one of the last with the pony motor options (Old Magnet please correct me if I'm wrong). in mid 1954 the D318 and D315 started milling holes for direct start in the boss just under the Pinion clutch. Pony Motors and direct starting were both options from then on.
not sure but I think
I read somewhere in the Cat Lit. researching for the 1960 955E that June 30th 1964 was the cutoff date for Pony Motors to be an option. After that date I'm thinking they were considered NOS.
ACMOC Member
Last edit: 2 years 8 months ago by Fat Dan. Reason: correction
2 years 7 months ago #236999 by Mr Adams
I’ve got access too a parts d333t
Would the bottom end be the same as my d333a ?
2 years 7 months ago - 2 years 7 months ago #237003 by Old Magnet
Pony motors for the D6B lasted into 1967, basically were dropped when the D333a (4-1/2'" bore) changed to the D333c (4-3/4" bore)
D333t (turbo) could be the same as the D333a (NA) unless it's actually a D333ct.
Turbo engines usually have piston cooling jets (oil) that the NA engines don't use
Last edit: 2 years 7 months ago by Old Magnet.
Time to create page: 0.182 seconds
