D8H46A brake band replacement help
2 years 8 months ago - 2 years 8 months ago #236702 by Medic235
Hello  All  I've started the project of the brake band replacement.  I have the machine tore down and the mountain of years of built up oil scraped off . How do you remove the band from this point  what has to come apart on the cover ?
Last edit: 2 years 8 months ago by Medic235.
2 years 8 months ago #236703 by Rome K/G
Each side brake booster with covers, good time to reseal the steering clutch control housing in the center. Yes clean the deck up good first before disassembly.
The following user(s) said Thank You: Medic235, Fat Dan
2 years 8 months ago #236704 by Medic235
I've hit it with the fire hose it's pretty clean now I assume once the band is undone it will pull out or do I have to pull the steering clutch . I'll get a repair manual shortly .
2 years 8 months ago - 2 years 8 months ago #236705 by Rome K/G
Just back off the adjustment bolt under the small cover with the breather on and remove the oil lines and all the bolts around the top cover and booster, remove control rods, should lift off.
Last edit: 2 years 8 months ago by Rome K/G.
2 years 8 months ago #236706 by Medic235
Awesome thank you
2 years 8 months ago #236708 by Rome K/G
Your welcome
2 years 8 months ago #236710 by Wombat
Steering clutch with band comes out , be careful not to let the clutch slip out of the brake drum, you will find an inner and outer row of bolts to undo inside the housing, will need to roll the tractor to undo them with a jack under a grouser.
Wombat
2 years 8 months ago #236748 by Medic235
Appears I'm missing some of brake linings so I have to pull the steering clutch and all booo lol
2 years 8 months ago - 2 years 8 months ago #236749 by Rome K/G
oooh yea, might, I say might be able to have the drum turned if not cut too deep. Just remove the bolts on each side and lift the assembly out. And drain the oil to clean housing.
2 years 8 months ago #236785 by trainzkid88
doesnt look like a lot of moisture damage so thats a bonus.
Time to create page: 0.184 seconds
