DR pony gas tank filler neck size
2 years 8 months ago #236416 by Kurt Bangert
In this case, the tank itself is toast, no loss there.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
2 years 8 months ago #236428 by Reisingerweld
Quick picture of what I whipped up so far, drew it in acad as a net, bottom with 4 sides and top with the 5th side and threw it across my plasma table. With the two tanks sitting next to each other I think I made the outside edge too tall may not tuck under the hood. I might have to cut a bevel out of that corner to hide it up under the there.  I'll post more pictures as I get further may be back to the back burner for a bit
D4 6U9483SP
Hyster D4N winch
2 years 8 months ago #236432 by Kurt Bangert
Nice work!
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
2 years 8 months ago #236662 by Reisingerweld
Made some progress yesterday, machined the filler neck, left it long to be able to determine final length after getting the tank mocked up in place.
D4 6U9483SP
Hyster D4N winch
The following user(s) said Thank You: Fat Dan, Busso20
2 years 8 months ago #236672 by Old Magnet
Nice job!!! Might be a market for those ss gas tanks if your so inclined.
2 years 8 months ago - 2 years 8 months ago #236674 by Reisingerweld
Was starting to think about it, let me get mine done first, like I said I may have to take a chamfer out of the outside top edge to tuck it under the hood and if that's the case I would obviously change the cad drawing to account for the different shape before I cut out the net on the plasma table. And also let's see what mine costs. I'll report back as I make progress.  Thank you for the compliment.
D4 6U9483SP
Hyster D4N winch
Last edit: 2 years 8 months ago by Reisingerweld.
2 years 8 months ago #236675 by kittyman1
nice neat job as well Reisingerweld
-is stainless that tough to bend? that you need to cut a kerf along the bend? to make it fold properly?
-or does it makes a better final product? rectangle/square etc?
-i always thought bend before cutting...? one of my basic rules of fabbing...
2 years 8 months ago #236676 by juiceman
I will definitely agree with others, that is a NICE job. I know of nobody else that has made a pony gas tank for under the hood. Hope you are able to fab more to sell. JM
2 years 8 months ago #236680 by Kurt Bangert
Great work - that is going to turn out very nicely.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
2 years 8 months ago - 2 years 8 months ago #236692 by Reisingerweld
The kerf just makes it easier to bend, and keeps things true to each other a little nicer. I was able to bend the walls all up with very little force, so little I wasn't expecting it on the first side and almost broke it off.
Always leave your bending for last, it's much easier to cut a flat piece of material clamped to a bench or what have you just like it's also easier to fixture something flat into other machines such as a drill press or mill. Once it's bent into shape it becomes a nightmare to hold it without damaging the shape. Obviously this takes more layout and forward thinking to know where the hole will land after it gets bent up
Thank you everyone for the compliments.
D4 6U9483SP
Hyster D4N winch
