Roller specs ?? D4 7 series
2 years 8 months ago #236290 by Bellyman
Can someone tell me or Direct me to find Roller Specifications for  D4 7U series dozer ? I need to replace , top rollers or rebuild two ?? Thanks to all , cheers RobB
2 years 8 months ago #236291 by bursitis
join up and use the library. in it you will find instructions for rebuild conservation. the rollers can be welded or built up and reused
2 years 8 months ago - 2 years 8 months ago #236348 by Shaban1983
Top carrier rollers generally don't bear much weight, I'd keep using them as long as they don't cause trouble and don't have visible damage and/or slop
Those top rollers on D4-7U are 9B-0562.
There are no direct replacement aftermarket ones, I think replacement is possible but from memory it's tricky, needs a new shaft pressed into the tower.
Also check this old thread:
www.acmoc.org/bb/discussion-d72/27068-no...rcarriage-dimensions
Last edit: 2 years 8 months ago by Shaban1983.
Time to create page: 0.129 seconds
