D4600 Fuel Injection Specs
2 years 8 months ago #236144 by sheddcanyon
Can anyone point me toward specs on the D4600 fuel injection valves and pumps? I tried the library and came up empty.
2 years 8 months ago #236151 by Old Magnet
Do you have access to someone that has the testing apparatus for the injectors and pumps?
Specs aren't going to do you much good otherwise. Minimum would be a pop test for the injectors (1750 psi).
2 years 8 months ago - 2 years 8 months ago #236152 by Rome K/G
Replied by Rome K/G on topic D4600 Fuel Injection Specs
As for the pumps check for scoring or pitting on barrels and check plunger length. Plunger length is 2.6575"-2.6577" for new. Pump should be replaced if wear exceeds .005"
Injection pump lifter is 1.734"
Last edit: 2 years 8 months ago by Rome K/G.
2 years 8 months ago #236181 by sheddcanyon
OM, a shop in Fresno says they have the apparatus. Rome, thanks for that info.
2 years 8 months ago #236182 by Old Magnet
For the 4R/5R D4600
Low idle is 550 rpm
High Idle is 1550 rpm
Full load rpm 1400 rpm
Rack setting is 0.590"
Find your pump part number on the following chart and move to the rack setting. Where the two intersect is the number of pump strokes to fill the calibrated sight glass on the test apparatus Whether it passes or not is determined by the liquid level in the sight glass.
If your injectors pass the spray pattern test the process for setting the pop pressure is as follows:
Lift dimension is 0.007"  Pressure setting is 1500 psi for the 4-1/4 bore
2 years 8 months ago #236185 by sheddcanyon
OM, thank you very much. I will report back the results.
2 years 8 months ago #236238 by oldbeek
Replied by oldbeek on topic D4600 Fuel Injection Specs
still working on it?? Keep trudging on.
2 years 8 months ago #236241 by sheddcanyon
Yes sir! Funny how life gets in the way of these projects
2 years 8 months ago #236250 by Fat Dan
Replied by Fat Dan on topic D4600 Fuel Injection Specs
oldbeek post=236238 userid=9101still working on it?? Keep trudging on.
 Aman !
ACMOC Member
Time to create page: 0.165 seconds
