2Ton
2Ton
Thank you received: 7
2 years 9 months ago #236131
by Sthorpe
I recently bought a 2 ton tractor. Serial number 76668. Can anyone tell me what year it is? Also the clutch will not disengage. It seems the lineage is working and it feels like it’s working the pressure plate. Any information would be helpful.
Fat Dan
Thank you received: 999
Thank you received: 117
2 years 8 months ago #236164
by naylorbros
I have had the nut that holds the clutch on the trani shaft loose it cotter pin and jamb itself against the flywheel and make the clutch act like it is stuck before. Other possibilities are the clutch plates are stuck together, it is a multi plate clutch, the pilot bearing could be bad, etc. It is not to bad to get into, a copy of the owners manual is a great help on any repairs on a 2Ton.
Ken
Fat Dan
2 years 8 months ago #236189
by Sthorpe
Thanks Ken, So I pulled the top cover off and on of and I have the same issue. The cotter pin sheared off and the nut backed off. The bolt is stripped and the nut will not thread back on. Do I have to pull the engine to get the clutch off to replace the bolt?
Fat Dan
2 years 8 months ago #236202
by naylorbros
In the Technical Library on this website there is a copy of the owners manual. It does a much better job a telling how to get to what you need than I can. Pages 58, 59, 60. Yes there is a way to do it with out removing the engine. If you do not have access to the library I can scan mine and post them but it would be a few days before I can do it.
Ken
Fat Dan
2 years 8 months ago #236223
by naylorbros
Congrats on getting it out and good luck. I need to do the brake bands on mine, I just need to talk myself into it.
ken
Fat Dan
Thank you received: 194
2 years 8 months ago #236236
by Fat Dan
Have you tried ebay?
ACMOC Member
2Ton
Time to create page: 0.170 seconds
