timming 343
17 years 8 months ago #2065 by earthworm
timming 343 was created by earthworm
any one have info no 343 timming the cams thanks ross
17 years 8 months ago #2078 by SJ
Replied by SJ on topic D343
The cam gears themselves have marks on the gears to line them up if they have been disassembed & then to time them to the engine first the engine has to be turned to TDC #1 on the firing stroke. The gear in the rear case will have a missing spline directly on top position so then turn the cams so the drive cam has the internal splines on top too & then if the cams are bolted down the stub shaft with the missing teeth (splines) on each end will slip in & it should be right then.
17 years 8 months ago #2079 by SJ
I should have said the cam that has the splines in it the missing spline also has to be on top so the stub drive shaft will slip in through both the rear gear train gear & into the cam so in other words both the rear internal gear inside the rear housing & the cam drive both have to have the missing spline on top then the stub shaft will slip in.
17 years 8 months ago #2081 by Willie
Replied by Willie on topic timming 343
Earthworm ; if you need to see the pages in book let me know with EMail address
Time to create page: 0.151 seconds
