D4 Weights
D4 Weights
2 years 9 months ago #235664
by noahthompson
I’m currently looking at buying 2 d4 to match my collection. Ones a narrow gauge with a blade and other one is wide gauge with a winch just need the rough weight of them. Narrow gauge is A 1949 and wide is 1956
Thank you received: 999
Thank you received: 113
2 years 9 months ago - 2 years 9 months ago #235692
by GrantJ
Look for the fenders for the one with the winch. The early D4s with Hysters needed a strong bracket that bolted under the fenders and went to those top two Hyster mounting holes. The brackets are about 4 feet long and on the rear are very heavy steel mounting lugs. Later D4s came with the rear case strong enough not to need the brackets. That photo appears to me to be a "U" series and I believe that it was somewhere in the U series that they changed the rear case. Good Luck, Grant.. I will try to get a photo of the brackets today and post.
Last edit: 2 years 9 months ago by
GrantJ. Reason: after thought
Thank you received: 276
2 years 9 months ago #235713
by rax200
Hi Grantj,
If you look at this photo you will see the two mounts on top of the casing, this is what you need for the top mount.
The tractor is a D4 2T hope this helps.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
2 years 9 months ago #235744
by GrantJ
RAX200, yes that is the bracket that is needed. The one that I have is welded to a long piece that bolts under the fender. I believe that it came off of a 2T originally but my dad had it on an RD4. I have the Hyster manual somewhere around here that I think shows the bracket with the long piece. I will have to find the manual and see if my memory is correct. Grant.
D4 Weights
Time to create page: 0.149 seconds
