Holt/caterpillar 2 ton
2 years 10 months ago #235037 by whiteiron
Looking for the simplest way to time the engine before mag removal and then the mag when I get it back from rebuilding thanks!
The following user(s) said Thank You: SoCalCatMan
2 years 10 months ago #235044 by Deebo
Replied by Deebo on topic Holt/caterpillar 2 ton
Here’s an excerpt from the 2 Ton Operator's Instruction Book; Hope it helps.
The following user(s) said Thank You: Martinez
2 years 10 months ago #235057 by kittyman1
Replied by kittyman1 on topic Holt/caterpillar 2 ton
-there should be a timing mark on flywheel or dampner somewhere...for TDC
-and somewhere else for the magneto
-if you can't find them, why couldn't you make your own marks? chisel, punch marks etc...
-handy tip if you're taking anything apart that you're not familiar with...oh yeah that lines up and matches etc..
2 years 10 months ago #235088 by Old Cats
Replied by Old Cats on topic Holt/caterpillar 2 ton
The way I time a mag to an engine is simply put the engine on TDC for #1 cylinder or just slightly past TDC. Now fire the mag on #1 (be careful to just fire the mag and do not go anymore or timing will be advanced) Now connect the mag to the engine making any adjustments for alignment through the engine/mag coupling. Do not rotate either the mag or the engine while doing this. Always check your work before trying to start and make any adjustments if necessary. Remember these instructions in the book are for their mag with everything new. Your timing has to be with your mag and the way it works now.
Time to create page: 0.143 seconds
