D6B pinion
2 years 10 months ago #234972 by Stuss
D6B pinion was created by Stuss
Hi I’ve removed the pony motor from my D6B , and now having trouble finding a pinion to suit the teeth on flywheel as there not straight
2 years 10 months ago #234973 by bursitis
Replied by bursitis on topic D6B pinion
are you trying to put together an electric start conversion?
2 years 10 months ago #234974 by Stuss
Replied by Stuss on topic D6B pinion
Yes that’s the go, want convert to electric start,
2 years 10 months ago #234975 by PhilC
Replied by PhilC on topic D6B pinion
Old Magnet is the Guru on these but I assume you need something like this.
2 years 10 months ago #234976 by bursitis
catstarter.yolasite.com/
did a fast search and found this site. don;t know anything about them
2 years 10 months ago #234977 by bursitis
2 years 10 months ago #234980 by Old Magnet
Replied by Old Magnet on topic D6B pinion
Do you have a starter now? and is it a Delco 40MT or 42MT?
Either one will  also require the 1M0023 eccentric adapter due to the buzz bomb pony motors having a larger hole in the flywheel housing than the normal direct start drive end housing.
The starter drive you need is this one, along with the correct drive end housing.
The following user(s) said Thank You: Stuss
2 years 10 months ago #234995 by Busso20
Replied by Busso20 on topic D6B pinion
I think a fella named Davis does the complete starter unit with the helical gear in Toowoomba Qld only as complete kit.
2 years 10 months ago #235001 by Stuss
Hi Busso 20 yes John Davis sells complete setups and won’t sell individual parts, about $1800 for a setup. It’s good value if you want to go that way.
2 years 10 months ago #235005 by Busso20
HI Stuss, yes I guess so, a little hard to justify if not used regular, I managed to sort both my pony's out and was lucky to secure another for a rebuild to be exchanged when needed after I build it.
Time to create page: 0.184 seconds
