Cat 212 generator not working
2 years 10 months ago #234991 by Old Magnet
Need a picture of your generator and the drive housing, or even better the Delco number if you can make any part of it out.
2 years 10 months ago #234992 by Etbrig123
I just went and it is reading 7.5 ohms between the post on the generator. The generator has a arrow on the case and its turning the rite direction. Was that delco number
1922201 rite? Would anyone have a delco number for a regulator.
2 years 10 months ago - 2 years 10 months ago #234993 by Etbrig123
        Here is some pictures of what I have.  [attachment=66361]C8EF8598-2C0A-4DA7-ADC7-C94971F9278D.jpegachment] [attachment=66358]B42E37E6-5D68[
Last edit: 2 years 10 months ago by Etbrig123. Reason: same pictures more than once
2 years 10 months ago - 2 years 10 months ago #234996 by Old Magnet
Seems to be an odd ball generator (with single bolt pole shoe attachment?) Going to take me some time to track that down. More later.
Is the generator putting out any voltage at all?
Last edit: 2 years 10 months ago by Old Magnet.
2 years 10 months ago #234998 by bursitis
your VR looks new? did you adjust the points???
2 years 10 months ago #234999 by bursitis
2 years 10 months ago #235003 by Old Magnet
The generator s/n is a Delco 1102725 originally 6V -30a, rotation is clockwise, minimum speed for full output current is 1600 rpm. Original armature is a Delco #1881288
Most closely matches a Cat generator part # 7F-7149.
That same generator in 12v would use a 6F9464 regulator good for 40a. Good luck finding one.
If the generator will pass the motor test there is no reason it should not generate. Did you check for actual voltage output?
2 years 10 months ago #235024 by Etbrig123
After swapping parts from 4 other generators we had, finally found out the brush holder was junk. It looks just like the new one I got from the start and matches the Cat one it had in it from when I bought the grader. You can now polarize it and its charging. Thanks everyone for your help!!
2 years 10 months ago #235025 by Old Magnet
Good on you!!! Like many electrical issues they turn out to be mechanical problems.
2 years 10 months ago #235076 by Fat Dan
bursitis:
absolutely loved the 1948 video
ACMOC Member
