Cat d6 9u final drive removal
Thank you received: 80
2 years 10 months ago #234935
by gemdozer
You need to removed the linkages and removed the bolts each side from the stering cluch and loosed the adjusting bolt under the stering cluch housing to be able turning the brake band
Thank you received: 49
2 years 10 months ago #234936
by Busso20
Nice work, A lot less rust scale than what my D4 had in clutch area, at least you can access for a good clean now.
Thank you received: 778
2 years 10 months ago #234941
by juiceman
Thanks for the action photos. Looks like you will get intimate with your D6 for sure, but very rewarding to have a better understanding of how things work.
I used to get harped on to buy a manual, which I have amassed quite a few now, as I own a couple of tractors. Best suggestion I ever received.
In your situation, we can see having a winch AND cab does not make the job very enjoyable, but we expect to see the working video soon!
Best of luck getting it buttoned up soon, JM.
Thank you received: 240
2 years 10 months ago - 2 years 10 months ago #234945
by Mike Meyer
Can someone with a D6 8U or 9U please estimate how much life is left in the steering clutches by looking at the adjusters, if it was my tractor and I discovered the clutch packs were not worn much, I wouldn't be scared to fill that left side compartment with diesel and let it soak for a month or 2, bolt the final drive back on along with the track frame, and give her another good flogging pulling something super heavy, that final drive has to go back on now anyway, as does the track frame.
Best advice I ever got from "edb" was try the easy fixes first, but if that clutch pack is 70% or more worn, it's a no brainer to perform open heart surgery on the old girl while you have the time and inclination.
Mike
Thank you received: 324
2 years 10 months ago #234947
by Ray54
Good to know your still after it. Never had a cab on one so no ideas how to work around that.
It was pointed out to me my brush guard/roof could be used as a lifting point on a master clutch repair rather than removing it to get a loader bucket in place above. Maybe something like that will be possible with your cab.
Thank you received: 51
2 years 10 months ago - 2 years 10 months ago #235043
by mikewood869
Ended up getting the clutch pack out yesterday. We ended up stretching out two 15/16 wrenches (good old Tractor supply). It's nice having a backhoe, The break pad had to be replaced anyway.
kracked1
Thank you received: 121
2 years 10 months ago #235056
by PhilC
Now that you have the tank out of the way and given the condition of the left brake band it would be an opportune time to inspect the right side as well.
Thank you received: 124
2 years 10 months ago #235101
by mikewood869
Ended up having to order springs today. The brake pads, discs and throw out bearing have come in.
Busso20
Time to create page: 0.192 seconds
