Cat ten transmission bearings
2 years 10 months ago #234564 by CatMitch
Im trying to put a 1930 cat ten transmission back together and dont have a manual, Im not sure about the direction of the thrust bearings, can anyone help point me in the right direction.
thanks
2 years 10 months ago #234569 by gauntjoh
There is a Cat 10 parts catalog in the members library which should have the information you require.
The following user(s) said Thank You: CatMitch
2 years 10 months ago #234571 by bruce oz
patrts book dosnt show the bearing in detail , if its open both sides it donst matter which way is goes , ?
2 years 10 months ago #234577 by CatMitch
The parts books give no direction on the bearings, the direction does matter, there is a 40 degree taper on the thrust side, i was hoping that maybe someone on here had a service manual that could help.
2 years 10 months ago - 2 years 10 months ago #234578 by bruce oz
answered your own question , old bearing wasn't tapered
Last edit: 2 years 10 months ago by bruce oz.
2 years 10 months ago #234586 by CatMitch
Makes sense, sometime in the past the transmission must of been rebuilt and they went with all tapered bearings, that is what confused me, Im going to go back with standard radial bearings on the back side of the transmission shaft’s because there is no bearing backstop there therefore no axial load at that point, the bearings are just centered in the case carrying a radial load.
The following user(s) said Thank You: bruce oz
Time to create page: 0.147 seconds
