Volume compressors
Volume compressors
Thank you received: 16
2 years 11 months ago - 2 years 11 months ago #234092
by D2Fred
I was wondering about a volume compressor for my D2. Is the transfer pumps that are used for filling gear lube into rear axles the same thing? Mine is an old ARO With pump handle. The handle will push one direction and then spring back. The cat ones I have seen are only slightly different ( that I can tell). I can take a picture of mine but I think I described pretty well.
Last edit: 2 years 11 months ago by
gauntjoh. Reason: removed duplicate picture
Fat Dan
2 years 6 months ago #238110
by Ryan.E
Hey folks
I was searching the forum to try and find the answer to the same question D2Fred has.
00 grease is runny enough that I think the gear oil pump would pump it. Does anyone have any input?
Thank you received: 58
2 years 6 months ago #238112
by Mschwartz
Might work when it is hot out but the track grease is likely to thick when it is colder. Seems like it would be easier to find a correct volume pump can. The oval Alemite cans or the round ones used for the international crawler seem to work equally well. The liquid pumps like described above work well to flush the oil in the sealed rollers. Might be because there were so many crawlers around here but most any old farm stead has some setting around. Mike
Volume compressors
Time to create page: 0.154 seconds
