9u motor weak
16 years 2 months ago #20247 by d7doug
9u motor weak was created by d7doug
Bought the 9u for parts did not think it would run after 7 years of sitting. Owner told me he worked it too hard and somthing blew. Took off valve covers noticed a small amount of coolant around one of the head bolts. All the valves seem tight and the crank oil looked ok not creamy so we pulled and pulled and pulled and then I remembered the throttle, and bang she started. It ran not too bad but has at least one dead cylinder and one injector line was sweating a lot, pulled valve cover off again bit of creamy oil in the area of the head bolt, crank oil still looked ok, any thoughts?
16 years 2 months ago #20248 by SJ
Replied by SJ on topic Leak
There are a few things to cause leaks but it could be a bad head gasket and open each fuel line one at a time and see which cyl. isn,t firing and could be a bad spray nozzle. If you find one missing take a good one out and swap the nozzles and see if the miss follows and if it does then you found the bad one.Sometimes I,ve seen leaks around a stud if the bottom of the casting under the stud threads is cracked or broken out causing a leak.Sometimes if there is good threads yet that the stud screws into then you could use a sealer on the threads to stop the coolant from coming up by the threads.Also check to see if the stud is torqued down ok as it could be loose and wouldn,t hrt to chek all the nuts to see if they,re ok.
Time to create page: 0.126 seconds
