D4 7U bevel shaft same as 955 12a?
Thank you received: 11
3 years 1 month ago #231842
by Zzzopp
Picked up a replacement bevel gear shaft for my one legged D4 7U from a local salvage yard.
Upon loading the assembly in my truck the tech said it’s actually from a 955 12a. When I questioned this he reassured me it is the exact parts that are in my D4 7U.
Does this sound correct?
Planning to pull mine apart in a few weeks and hope i have the correct shaft for reassembly.
Any information/advise is greatly appreciated!
Fat Dan
Thank you received: 820
3 years 1 month ago #231848
7U1 to 7U33912 uses a 6B9919 bevel bear shaft.
7U33913 -up and the 12A uses a 6H3582 (or 7K8130) bevel gear shaft.
3 years 1 month ago #231855
by Zzzopp
Well dang, I wonder what the difference/interchange is... I guess I’ll get the D4 pulled and take some exact measurements.
Fat Dan
Thank you received: 526
3 years 1 month ago #231863
by gauntjoh
There are two parts books for the D4 7U (different serial number ranges) in the technical library which will include this page.
There is also the pats book for the 955 12A series traxcavator.
Thank you received: 276
3 years 1 month ago #231867
by rax200
Hi Zzzopp,
I have just put my 7U back together recently, the differences between the two shafts it is slightly larger on the latter models than the earlier ones.
The good part is it will fit as you have all the misc bits on the donor shaft, all you have to do is change the crown wheel over.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Thank you received: 344
3 years 1 month ago - 3 years 1 month ago #231876
by edb
scans below may help. Service Bulletin, June 20 1956.
Seems the new heavier duty Bevel shaft and bearings are adaptable to only some prior U series D4's.
Last edit: 3 years 1 month ago by
edb.
3 years 1 month ago #231877
by edb
just found this article regarding what OM refers to above about a pinion change.
The change is also applicable to some earlier than 6U/7U series machines.
Self explanatory in the scan text as to which S/No machines are applicable.
3 years 1 month ago #231878
by Zzzopp
My D4 is a 7U20251, should already have the larger pinion bearing gear. Since I have a complete assembly from the 955 12a I think it should work!
I’ll take some measurements/pictures as I get it pulled apart.
Thanks for the information!
edb,
Fat Dan
Time to create page: 0.194 seconds
