D333 Need a part number?
16 years 3 months ago #20019 by Joe
D333 Need a part number? was created by Joe
I have a 977H 53A5276 with D333. The oil tube to the oil pump has the screen blown out. Do I have to buy the whole tube or can I just replace the screen? I think the part number is IM 2837? Also need the O-Ring that goes on the tube where it goes into the oil pump? Any help is much appreciated! Not sure of the part number on the O-ring?
16 years 3 months ago #20020 by ccjersey
Replied by ccjersey on topic D333 Need a part number?
Joe, I don't have a book on the 977H, but all of the D333's I have books for show a cast aluminum suction bell with a screen assembly inside and a cover over that which has the hole in the bottom for the pump to suck up oil through. On those, the screen assembly is a separate part bolted between the bell and the cover with gaskets.
If you do have one like that, be very careful of the bell, they are easy to break off the flange where they bolt to the pump.
16 years 3 months ago #20023 by Old Magnet
Replied by Old Magnet on topic D333 Need a part number?
Which oil pump are you referring to? Powershift hydraulic system, loader or main engine?
16 years 3 months ago #20043 by Joe
Replied by Joe on topic D333 Need a part number?
It's for the main engine. And yes it has a bell with a screen in it, but it also has the tube on the other side of the pump that goes along the pan plate that picks up oil on the back of the engine.
16 years 3 months ago #20044 by ccjersey
OK, now I see it. The 58B1 - 58B2417 parts book has the front pickup tube part number 1M2837 and shows a 5F1678 "seal" o-ring at the pump end where the tube plugs into the pump.
I believe I would get some good screen and figure a way to fasten it on the tube. I think McMaster Carr has some brass screen that you could use if you can't find something suitable locally.
16 years 3 months ago #20045 by SJ
Replied by SJ on topic Tube
That back tube is just a scavange pipe and is part of the pump but not the pressure side of the pump but just picks up oil that would collect when your more or less on a grade and that side of the pump just dumps the oil back in the main (deep) sump for the main pump to pick up for lube to the whole engine so the scavange pump doesn,t lube the engine. This scavange side won,t let the main sump of the pump loose oil so there isn,t enough to pump pressure.
16 years 2 months ago #20109 by Joe
Thanks Guys:D
Time to create page: 0.146 seconds
