Rippers for Older Dozers?
3 years 2 months ago #231018 by Wombat
Replied by Wombat on topic Rippers for Older Dozers?
Mounted rippers were not uncommon on 'U' series tractors, they were generally mounted differently to later tractors, they had a plate or long bolts that were attached forward to where the Drawbar pulled from, that way not all the load was on the studs in the housing at the back. In Oz many D4 7U tractors were fitted with rippers for soil con work.
D4D D5 D6C tractors to my knowledge all relied on the studs at the back like later tractors, in Oz it was common for those models to be fitted with rippers, there are very good aftermarket rippers out here that I believe are superior to Caterpillar rippers, even D6H and later tractors are generally fitted with variable pitch rippers.
Wombat
3 years 2 months ago #231019 by rax200
Replied by rax200 on topic Rippers for Older Dozers?
Hi All,
Wombat is correct as I have a D4 7U that has rippers on the back of it. It has connection bolted on the bottom of the mounting frame that goes back to where the original drawbar connects (the original drawbar is replaced) you can see it in the attached photo.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
3 years 2 months ago #231023 by kittyman1
Replied by kittyman1 on topic Rippers for Older Dozers?
thanks for the replies guys...
-my neighbour has a D7e with a ripper, nice unit, uses it in a gravel pit along the river..
-but i haven't noticed a ripper on a 6? i think it is rather rare in North America as others have said..
-and i believe the shock loads on the back end can be crazy, ripper or winch
-it even surprises me how tough tree stumps can be to bust out...good thing Cats are built sturdy
3 years 2 months ago #231024 by rax200
Hi All,
A photo of the rippers on my D4 7U (forgot to post earlier)
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
3 years 2 months ago #231028 by Deas Plant.
Hi, PhilC.
Yes, there was/is another reason why few people fitted rippers to the older small crawlers quite aside from the fact that their back ends were not built for it - they didn't have the weight and horsepower to do any serious ripping. Yes, they could soften up most SOILS to make for easier working but they were almost as much use as a breast pocket inna G-string when it came to serious rock.
3 years 2 months ago #231046 by edb
Replied by edb on topic Rippers for Older Dozers?
Hi Daryl,
that looks like a Standen style ripper that we used to fit to machines sized from D4 to D7 at W Adams. back in the 1960's when I was an Apprentice in the New Equipment Bay-- Mr. Standen used to often appear when a new model machine or one they did not have rear mount stud drawings for and make a template to suit for the back plate.
Soon enough a nice new ripper would appear usually in Red Oxide paint. All part of the Australian built theme of the day as Cat Of Australia were producing D4 and D6 TTT's amongst other items of plant and attachments, including undercarriage items for same.
3 years 2 months ago #231049 by trainzkid88
yes darryl that is how i would mount em if i made a set for our machine. many farmers have snapped tractors in half mounting front blades etc simply becuase they dindt pick up mountings all the way along and particularly at the diff. here's something to if you want to make a machine to pull at its maximum run your chains to the front you get more traction as it is pulling the machine into the ground its also safer much less likely to flip the machine. and any machine will break if you abuse it.
3 years 2 months ago #231053 by edb
further to the Standen or any ripper for that matter, the lower edge of the ripper mounting plate is that it hangs down below the bottom edge of the rear case face and there is a ripper specific drawbar tongue that is to connect to the drawbar mount under the transmission case--there is a specified shim adjusted preload applied to the draw bar tongue to the ripper mounting plate/frame to ensure that the pulling power is taken via the drawbar mount and not by the studs on the rear case.
Will see if I have these specs from a Cat ripper somewhere here.
It is not all brute force and ignorance with these ripper mounts as you will now appreciate there is some science to it for a successful ripper out come and so not RIP the ripper off or the rear face off the rear of your machine.
3 years 2 months ago #231056 by Deas Plant.
Hi, edb.
I never saw the ripper mounting brace that you have described onna small dozer but I saw a good few of them on Cat 941 track loaders, seemed to work well too.
3 years 2 months ago #231057 by willwingo
Replied by willwingo on topic Rippers for Older Dozers?
This came with the tool bar set up on my 7U D4. Almost all the force is on the trunion balls on the side frames.
Caterpillar called it a "subsoiler", not a "ripper". It also has a mole attachment for drainage work
The following user(s) said Thank You: ag-mike
Time to create page: 0.186 seconds
