Fuel Tank
Fuel Tank
Thank you received: 98
3 years 4 months ago #230063
by kracked1
Is there a difference between the fuel tank on a 14A and 46A? Trying to get this winch setup on the 46A and there are no mounting holes in the bottom of the tank for the controls to mount to. The holes are in the top of the tank, just not the bottom. The 14A tank on the parts machine has all the holes. Wondering if they are the same just paint and switch tanks.
Thank you received: 344
3 years 4 months ago #230065
by edb
Hi Again,
got called away, so now if you are talking about a Cat rear double drum Cable Control for these model machines then the lower vertical tree lever mount is a self aligning bearing block that mounts to a cross member under the floor plates--from memory the taped holes may be there from the factory.
3 years 4 months ago - 3 years 4 months ago #230134
by kracked1
edb, sorry for the delay in response, life is beyond crazy right now. It is a #29 CCU. The controls are just as you said except the ones that were taken off the 14A screwed into tapped mounting holes in the tank. Just like the top mounting plate does. I can make a bracket to mount it to the floor plate. But thought it would be easier to just switch tanks. The lower mount of the hydraulic control lever mounts as you stated. I will need to move that forward to clear the CCU control levers.
Last edit: 3 years 4 months ago by
kracked1.
Fuel Tank
Time to create page: 0.129 seconds
