Cat engine progression
3 years 4 months ago #229792 by hfdzl
Cat engine progression was created by hfdzl
I have recently bought a D17000 gen set.
What is the engine series become after the D 17000? It became what? Next V8 series engines?  I have to admit I am not familiar with Cat engine designations.  Is there somewhere that you can find the lineageie; this series produced from  xxxx to xxxx?
Herb
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
3 years 4 months ago #229798 by Old Magnet
Replied by Old Magnet on topic Cat engine progression
As near as I can make out from my TRW Engine parts manual the next series 8 cylinder 5-3/4 bore engines would be D364 series 19B, 20B, 21B and the D375 series 16B, 17B, 18B, 43B and that seems to be the end of the 5-3/4 bore 8-cylinder engines. I don't have specific dates but I'd guess these would be 1960's engines.
The following user(s) said Thank You: hfdzl
3 years 4 months ago #229800 by hfdzl
Replied by hfdzl on topic Cat engine progression
So that is the end of V8 engines? No newer series? Then everything then V12 and V16?
3 years 4 months ago #229802 by Old Magnet
Not the end of the V8 cylinder, just the 5-3/4" bore versions.
3 years 4 months ago #229806 by neil
Replied by neil on topic Cat engine progression
It would be good though to see a progression history, of how products were superceded. For example, something I didn't know until recently is that the D8L was effectively superceded by the D9N in size, if not in nomenclature, as it was essentially the same tractor. On the other hand, I don't know if Cat would consider the current D2 model a supercession of the U-series D2 in the long term - probably not. If anything, maybe the D1 could be considered that, but I think they're so different in purpose and format, that it would be a stretch
3 years 4 months ago - 3 years 4 months ago #229832 by hfdzl
OK, so what are the newer series?  Thanks, Herb
Last edit: 3 years 4 months ago by hfdzl.
3 years 4 months ago #229833 by Wombat
Replied by Wombat on topic Cat engine progression
had a dig around in a few books and came up with the following Cat V8 engines;
3208
3408
3508
D379
D346
1160
1150
1145
3150
3145
No doubt there are more than what I have listed here, as well there are many different configurations of those listed.
i hope this helps.
Wombat
3 years 4 months ago #229843 by 1951D2
Replied by 1951D2 on topic Cat engine progression
With the little research I have come up with the D17000 was produced between 1935 to 1955. There was a lot of variations with in its life both in the pony motor and the Main engine. The pony went from Timken main bearings to inserts, and the main engine went from six ring pistons to four. The six ring pistons are no longer available that I can find. Older main engine had two water pumps and later had One. Valve covers had a spacer between the head and the valve cover. When I overhauled mine I could still get the Valve cover gaskets ,head gaskets, Liners, rings for the six ring pistons, valves for the pony and main engine. Had to make my own pan gasket. and a lot of other stuff also.
These engines are a beast and have the coolest noise when running.
The following user(s) said Thank You: edb, hfdzl
3 years 4 months ago #229845 by hfdzl
1951D2, Great info! Both engines are stuck right now. I will be getting it home next week. It has 2 waterpumps. Will start a list of the hard to get parts.
Thanks again, Herb
Time to create page: 0.166 seconds
