D47U trans bearing
3 years 4 months ago #229687 by kracked1
D47U trans bearing was created by kracked1
I have a D4 7U8869. The front bearing is starting to make a little noise. Is it possible to change that thru the clutch inspection hole in the top of the bell housing? Or do I have to pull the top cover off the transmission? I looked at the book and it shows how to get it apart. Just not if you can do it without pulling the top cover.
3 years 4 months ago #229688 by Rome K/G
Replied by Rome K/G on topic D47U trans bearing
The cover will have to come off to get in there.
3 years 4 months ago #229690 by kracked1
Replied by kracked1 on topic D47U trans bearing
Thank you. I was hoping not to have to pull it. But if I do I do.
3 years 4 months ago #229698 by rax200
Replied by rax200 on topic D47U trans bearing
Hi kracked1,The noisey bearings in the box could be the one inside the front input shaft, there are only five bearings in the box if you go in to do one you might as well do all of them.
I have done several boxes now and for a few hundred dollars It is good insurance.
You will require the following
2 x 6308
1 x 6313
1 x 6309
1 x AB1307
1 X M1307TV
 Plus gaskets
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
3 years 4 months ago #229732 by kracked1
Rax 200 thank you much. It looks like a winter project.
Time to create page: 0.134 seconds
