933 excavator, 42A series undercarriage options
3 years 5 months ago #229216 by agibson396
42A 933 excavator that needs undercarriage.  Understand that undercarriage cost usually exceeds worth of the machine, but the rest of the tractor is in good shape, and I'm willing to do a fair bit to keep it usable as a farm machine.   What are the options, as it seems many parts are no longer available.  Am I correct that D2 is the same? Any alternative later model components that will work?  Any weld-on options for sprockets?  Source or dimensions for a wear guage?  Thanks in advance for any ideas.
3 years 5 months ago #229223 by josh
42A 933 uses D4 chains and rollers, sprockets are D4 size on the rims, but the sprockets are D2 style, don't know if D4 rims are the same diameter.
The following user(s) said Thank You: agibson396
3 years 5 months ago #229228 by edb
from the Undercarriage Custom Track Handbook is a range of weld on sprocket rims--D2/933 are given.
3 years 5 months ago #229231 by josh
Looks like the sprocket rims may still be available.
www.amtequipmentparts.com/undercarriage/...rocket-rim-23-tooth/
3 years 5 months ago #229234 by gemdozer
I have some good used 42a sprockets,idlers and rollers but should be too far from you
3 years 5 months ago #229450 by agibson396
Thanks Gemdozer, where are you located?
3 years 5 months ago #229452 by gemdozer
I am located SAINTE-JULIE near MONTREAL CANADA
3 years 5 months ago #229453 by agibson396
Thanks much, not out of the question, but a good distance, about 18 hours. Let me explore closer options, but I appreciate the possibility, and may follow up before this is over!
