96J D5 Cat
96J D5 Cat
Thank you received: 6
3 years 5 months ago #229073
by tmoline
Anyone know what tooling I need to pull sprockets I have access to Cat press just don't know what adapters i need
Fat Dan
Thank you received: 820
3 years 5 months ago #229088
Sprocket only removal requires:
5F7334 spacer group (1)
5F9040 Arm Group (3)
7F9831 cylinder group (1)
Fat Dan
3 years 5 months ago #229094
If you wish to pull the final drive and sprocket assembly and have a shop do the pressing that is an alternative. Or you can pull the sprocket only after splitting the track and removing the track frame and outer bearing hub and bearing holder. Are you dealing with a spoke type or disc type sprocket? Be wise to get yourself a service manual.
3 years 5 months ago #229099
by tmoline
been doing this a long time just the service manual says to pull the final off and then press the sprocket off I never done a 5 just 6,7,8,and 9s on those you have a adapter that screws on to the dead axle to attach the press to and I don't see that adapter
3 years 5 months ago #229102
Same operation as the D6. Just uses the 5F7334 spacer. The adapter coupling, pin, threaded adapter and pusher group is for installation.
96J D5 Cat
Time to create page: 0.157 seconds
