Weird Injection Pump Problem
Thank you received: 16
3 years 8 months ago - 3 years 8 months ago #228987
by Xtremist
So im wondering if anyone has had any issues like this, cause im at a loss.... So we went to start this old girl today after an overhaul (new pistons/liners, totally overhauled head etc) and at first it smoked up the shop like the engine was getting fuel and now it has basically quit smoking. When i crack the injectors all seem normal except #6 which is hissing and spraying air. When i tighten that injector it then proceeds to push pressure back into the fuel tank. Ill try to attach a couple vids and pics. I should add that this cat has been converted to direct start, and it started and drove into the shop and we havnt screwed with the injection pump until now. we have replaced the plunger twice on it and it keeps doing it. Any one ever runSo im wondering if anyone has had any issues like this, cause im at a loss.... So we went to start this old girl today after an overhaul (new pistons/liners, totally overhauled head etc) and at first it smoked up the shop like the engine was getting fuel and now it has basically quit smoking. When i crack the injectors all seem normal except #6 which is hissing and spraying air. When i tighten that injector it then proceeds to push pressure back into the fuel tank. Ill try to attach a couple vids and pics. I should add that this cat has been converted to direct start, and it started and drove into the shop and we havnt screwed with the injection pump until now. we have replaced the plunger twice on it and it keeps doing it. Any one ever run into something similar ?
Last edit: 3 years 8 months ago by
Xtremist.
Thank you received: 1000
3 years 8 months ago #228991
by Rome K/G
Might have a bad injector capsule [nozzle], cylinder compression is pushing back thru nozzle, line and pump.
Fat Dan
Thank you received: 810
3 years 8 months ago #228993
did you do any work on the injectors when you did the heads?.
a bad injector seems likely
Fat Dan
Thank you received: 345
3 years 8 months ago #228994
by edb
compression pushing back into injection pump fuel gallery is a sign of a failed injector nozzle--sticky valve or crud on the valve and or seat.
A blob of crud on the injector nozzles tapered seat down in the pre-chamber can distort the injector nozzle too as well as over tensioning.
Sounds like your nozzle is really jammed open as usually the leaking injector leaks back a small amount of compression/combustion gasses into the fuel injection pumps fuel gallery and causes an intermittent miss that disappears when the faulty injector nozzles fuel line is cracked thus identifying the faulty nozzle.
Fat Dan
3 years 8 months ago #229000
by Xtremist
all of the actual nozzles that are in the head are brand new, but i guess i could swap two and see if the issue moves to a different position. thanks for the input guys ill give it a shot.
Fat Dan
3 years 8 months ago - 3 years 8 months ago #229002
by edb
at The Dealer it was not unknown for an odd few new capsule nozzles to become stuck open after being fitted to an engine.
Parts Dept. used to bring them down to the Fuel Pump Room for testing before issuing a warranty replacement.
More often than not a quick jabbing lever handle pump or two in the hand operated injector tester got them working.
Somewhere I seem to recall reading a Cat publication article on this procedure/issue.
If I find it I will post it up.
EDIT,
OK I found the article on capsule cleaning. I never saw one of these cleaner rigs but we did a similar process in our hand test rig as described above --I cannot recall the ratio of successes to failures but this may get the nozzle working for you, or simply take it back to where you purchased it and ask for a replacement--they may do the above test procedure first though.
Service Magazine article was issued in the issue of March 10 1955, page 2.
edb.
Fat Dan
Thank you received: 680
3 years 8 months ago #229004
Xtremist, if you're not able to get them unplugged, the nozzles are dirt cheap at Cat. I think the ones for my D2 were eleven dollars or something - number could be wrong but the cheap price is correct
Fat Dan
3 years 8 months ago #229016
a similar method is used to clear grease nipples. its amazing what can be done by the judicious application of that scientific instrument the knockometer.
Fat Dan
Time to create page: 0.200 seconds
