Alemite pump help please
3 years 5 months ago - 3 years 5 months ago #228887 by d2gary
I'm getting real close to needing a pump so I decided to try and get mine in shape.
I've never used one, I always just had a grease gun with the correct fitting.
I managed to get it disassembled most oft the way but I'm stuck on the cable and the top of the pump . I need to replace the cable some how .
Any experts on this pump that can offer any ideas. Thanks for any info.
Last edit: 3 years 5 months ago by d2gary.
3 years 5 months ago #228888 by cojhl2
Replied by cojhl2 on topic Alemite pump help please
In order for the pump to actually pump track roller grease the lever needs to be held, that means the cable would be hooked in such a way to keep the grease from recycling. This was meant to quickly release pressure against the track roller seals.
In operation one would pump very easy feeling for resistance, then let go of the lever and continue placing the pump lever down. Then take a screwdriver or some pointed object and release pressure in the roller bearing cage by depressing the button in the grease zerk(?).
(Prob more information than you wanted)
9U(2), 5J, IHC544, Ford860
3 years 5 months ago #228893 by d2gary
Replied by d2gary on topic Alemite pump help please
Thanks for the operating instructions, it will be very useful when I get the pump working.
Where I'm stuck right now is I can't get the broken cable out of the pump head. I'm not sure if the tube unscrew or maybe its just stuck after years of grease drying up in there.
3 years 5 months ago #228896 by Old Magnet
Replied by Old Magnet on topic Alemite pump help please
These should help.....
3 years 5 months ago #228897 by restore49
Replied by restore49 on topic Alemite pump help please
If you need to make a cable - lawn mower cables are made with new cable and lead sinker weights shaped to the right size. Drill hole , thread cable threw splay out the end of cable (like umbrella) and clean and solder to back side of sinker.
3 years 5 months ago #228900 by bruce oz
Replied by bruce oz on topic Alemite pump help please
This browser does not support PDFs. Please download the PDF to view it: Download PDF
The following user(s) said Thank You: edb, Mike Meyer
3 years 5 months ago #228905 by D4Jim
Replied by D4Jim on topic Alemite pump help please
Now if we can find a way to get this into the Technical Library and an easy way to locate it once it is there.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
3 years 5 months ago #228910 by gauntjoh
Replied by gauntjoh on topic Alemite pump help please
If the document contributors will email the pdf files to This email address is being protected from spambots. You need JavaScript enabled to view it. we will include them in the library, suitably indexed and report back here.
3 years 5 months ago #228911 by bruce oz
if you click save on my pdf you can save it where ever you want it .
3 years 5 months ago #228913 by gauntjoh
Thanks Bruce, your document is now published in the library under Operators instructions \ Alemite.
Time to create page: 0.223 seconds
