R5 runs rough
3 years 6 months ago #228818 by ravenenv
R5 runs rough was created by ravenenv
I  have a 1937 R5 that starts and runs reliably but seems like it runs a little rough - mostly just intermittent hesitation as it idles. Smooths out a little at higher rpm. Adjusting the carb does not seem to change the pattern.
Is this is typical of these big gas engines or do I need to consider something like adjusting timing.  I have set the timing twice but without much change. I have rebuilt the carb, mag and fuel pump. Also cleaned the tank and replaced fuel lines.  Not real sure how to advance or retard the timing on the Eisemann - seems like it wants to default to the same setting.
Any advice or insight appreciated - Ross in Texas
Ross
Huntsville TX
1937 Cat R5
1957 Oliver OC4
1958 Oliver OC4
1946 Cletrac BGS
1939 Cletrac HG
1938 Cletrac E62
1951 Oliver OC3
3 years 5 months ago #228824 by neil
Replied by neil on topic R5 runs rough
My cousin's Twenty-Two idles very smoothly so I'd suspect that if your R5's behavior is not a fuel-related symptom, then maybe there is backlash in the magneto drivetrain?
3 years 5 months ago #228826 by biggastractor
Replied by biggastractor on topic R5 runs rough
Have you tried valve adjustment or looking for a weak valve spring?
good Luck
Biggastractor
3 years 5 months ago #228829 by wimmera farmer
Replied by wimmera farmer on topic R5 runs rough
Fairly simple to do a compression test on a spark ignition engine. I don't know what pressure to expect but lok at the spread between cylinders.Also look for wear in the governor and linkages it doesn't take much to cause a flutter.
Cheers WF
3 years 5 months ago #228833 by daron
Replied by daron on topic R5 runs rough
I'd suggest closely observing the interaction between the loping and the throttle rod action between the governor and the carburetor. This to try to determine if it's a gov or carb problem.
If I remember right edb has addressed this previously and sometimes wear on cam lobes (?) in the gov were the problem. If the owner didn't didn't want the expense of a gov rebuild sometimes a slight increase in the idle speed would 'cure' the loping.
Daron
3 years 5 months ago #228839 by ravenenv
Replied by ravenenv on topic R5 runs rough
Thanks for the tips. I have adjusted the valves twice. The valve springs appear tight but I am not too experienced in determining if a spring is loose. After adjustment the observed engine behavior did not change.
I'll check the compression for uniformity across the cylinders - any idea on what the pressure should be? I'm guessing at least 90-100 based on my other older gas engines but none are as large as the R5.
I'm guessing if it is the governor I'll see some erratic or intermittent movement on the governor that is causing the carb to hesitate, surge, sputter... I'll check this. I've had gov issues on some other tractors and those issues presented a little different than this but it is worth checking. The R5 has more of an intermittent/irregular sputter. Usually I have traced this to a fuel supply issue, carb float issue... but none of this has helped so far.
Neil - "backlash in the magneto drivetrain?" How can I run this down? I dread a little messing with the mag on the R5 - kinda of a pain getting this beast adjusted but I'll give it another try if you have some advice on this topic. I was so relieved to get her running the first time around (she was dead as a doornail when I pulled her off the trailer) I left well enough alone once I got her running. It took about 1.5 years to get everything together to get her breathing again.
Thanks for all the sage advice to date!!!
Ross
Huntsville TX
1937 Cat R5
1957 Oliver OC4
1958 Oliver OC4
1946 Cletrac BGS
1939 Cletrac HG
1938 Cletrac E62
1951 Oliver OC3
3 years 5 months ago - 3 years 5 months ago #228844 by edb
Replied by edb on topic R5 runs rough
Hi ravenenv,
Caterpillar does not work on the year of manufacture but by Serial Numbers as several upgrades can be carried out in any given year and thus Serial numbers are critical to ensure we give you correct info or indeed you were to try and order the correct parts for either a pre or post updated S/No changed item.
For example the early machines had Ensign carbs and later ones had Zenith--I stand to be corrected on this for at least the R5 as I am quoting from my grey Operator's Instructions Book for R5, Thirty-Five and Forty Tractors, Form No 30610, Dated  10/52.
Maybe check the flat anular shaped screen, as used in the Ensign carby machines, or the small EDGE screen--later fuel pumps--if still fitted-- in the fuel sediment bowl of the fuel pump--the small spaces between the discs can clog with crud and also solidified fuel, from sitting dry, and so may need to be moved apart or it is probable that you may need to dismantle the stack to clean the gaps properly--often carb cleaner will not do the job properly if still stacked tightly.
If you have a Zenith Carby there is originally also a screen in the union fitting at the float chamber entry on the carb. so any restrictions at these screens can cause the symptoms you describe.
Last edit: 3 years 5 months ago by edb.
3 years 5 months ago #228848 by neil
Hi Ross, to be clear I'm just putting possible causes out there. But if it is mag backlash, you can check by turning the distributor rotor back and forth to see how much "slop" there is. I've seen situations before where there is gear chatter that clears up with a small increase in RPM, such as in a Roadranger transmission when idling. Doesn't happen on all of them but some do. I drove a Hino once that had a 13 speed and it chattered like a schoolgirl at idle but with the same transmission in my Kenworth, there was/is no chatter - same transmission, same idle speed. If this was the issue (and it may not be), then likely changing out parts is the only way to solve it. I would check the possible causes that Eddie and others suggest first because they have a simpler solution.
3 years 5 months ago #228861 by ravenenv
SN on the dozer is 4H725. It has a Zenith K6 which I think puts it later in the 1937 production year (unless someone swapped carbs some point in the past). The carb and fuel pump have been cleaned/rebuilt in the last year but I will go back in to check all the items Eddie suggested - I might have missed something or more crud may have surfaced. The fuel tank is clean given I pulled it, acid washed it... but you never know. It is also easy enough to go into these fuel-related items . If no improvement I'll check the mag as Neil suggests.
It actually runs pretty well - I push some big material with it. Just this intermittent cough/sputter annoys me :(
Also anyone got an idea what the numerical oil pressure should be on an R5 at operating/working rpms once the engine oil is hot? I have an after-market gauge on the engine that shows 15-20 once the oil is hot and I am working at mid-range rpms. This is normal for many tractors - not sure about this engine.
I'll keep ya'll posted on my progress - thanks again for the tips.
Ross
Huntsville TX
1937 Cat R5
1957 Oliver OC4
1958 Oliver OC4
1946 Cletrac BGS
1939 Cletrac HG
1938 Cletrac E62
1951 Oliver OC3
3 years 5 months ago #228864 by neil
Hi Ross,
we'd be interested in seeing photos of your herd, not just the R5 but your extensive set of Olivers and Cletracs
Time to create page: 0.182 seconds
