Looking for info/ value of D4 2t6015 sp
3 years 6 months ago #228601 by Gregg
    I am looking for info and value of a D4 that my dad would like to sell. The number on the engine and body are the same 2t 6015 sp. it was running and drivable that hasn't been started for at least 15 years. Cat is in Avery, Ca. Thanks for any help, info, Gregg
3 years 6 months ago #228603 by neil
Probably a bit above scrap value Gregg only because without it proven to be running, it's basically a parts machine even though it's intact. If you can get it running, that should improve the price. It may cost very little to do - such as new spark plugs, replace oil in pony, drain any condensation from the main engine oil pan, replace mag condensor and clean-up points, etc.
The following user(s) said Thank You: Gregg
3 years 6 months ago #228616 by Gregg
Thanks for the info Neil, any idea what it might be worth if I get it running again? I think it was made in 1944 from what I can find online looks like that model was only made from 1943 to 1945 just trying to decide if I want to put the time in to getting it running again or see if I can find someone who’s interested in it as is. Thanks again for any info, Gregg
3 years 6 months ago #228620 by neil
If it starts relatively easy and the blade works ok, I would guess 3-4k? I haven't bought a D4 but I've seen prices around that mark, some higher, some lower. It's probably worth your while to invest say 8 hours in getting it going because as well as getting a better price, it will sell more easily (getting 10k is awesome but only if you make the sale and get the $) and also loading it out. If it was "running when parked" : ), then most likely it's some basic items that need attention: spark plugs, plug wires, condensor, points, carb, and then bleeding the diesel system if it's drained back. Getting the pony running and being able to turn the main engine over with it will get you a long way towards success. The pony is a very simple engine so they're very easy to get going so long as they're not actually damaged. One key thing to do with the pony is to drain the oil, and refill it with new. They only take a quart but it's a precious quart - if diluted with fuel, the pony risks throwing a rod, so a quart is very cheap insurance.
Hopefully someone within reach of Avery CA can come help at least assess the likelihood of getting it going. There are a lot of members within a couple of hours of your location - maybe one of them can come out for a Saturday rescue mission!
3 years 6 months ago #228621 by Gregg
Thanks again Neil , I really appreciate the help!
Time to create page: 0.137 seconds
