clutch
3 years 6 months ago #228536 by mhar
clutch was created by mhar
I have a d2 and the clutch either slips so the dozer doesn't move or it can spin the tracks How do I fix this?
3 years 6 months ago #228537 by ag-mike
Replied by ag-mike on topic clutch
Main clutch adjustment should be covered in operators manual.
The following user(s) said Thank You: mhar
3 years 6 months ago #228615 by mhar
Replied by mhar on topic clutch
I went through the Jen sale book and found it on the internet how to ajust the clutch but the tractor is having problems disingauging what next?
3 years 6 months ago #228619 by neil
Replied by neil on topic clutch
By "problems disengaging", do you mean it won't disengage at all, or will disengage with some difficulty? If the latter, what sort of difficulty? There's not a lot of difference between under and over adjusted - typically only one or two holes. If you went say 8 holes, then you overshot. Adjust it halfway back to where you were originally and see what you get. Also, if the adjustment is not the problem, then your pilot bearing could be seized.
Time to create page: 0.131 seconds
