D2 pony starting issues
Thank you received: 26
3 years 6 months ago #228184
by daron
A possibility- If you have a spare sparkplug connect it and carefully observe its spark with the pony cold and again quickly after the pony quits on its own (to rule in or out a a magneto problem).
Daron
Thank you received: 795
3 years 6 months ago #228188
a bad mag coil could be the issue. works fine initially then once it gets a bit warm it fails is a common sign of bad coil windings
Thank you received: 344
3 years 6 months ago - 3 years 6 months ago #228198
by edb
Hi,
OK now have you checked that the 90 degree lever is actually 90 degrees as it is very hard to set the initial needle setting without bending it. The lever is very weak and so is hard to feel when the needle has seated before bending the lever.
The jet adjust screw must be easy to turn in its housing when off the carb. top.
When the lever is bent you do not get enough fuel flow (lean mixture) to run the pony without nearly full choke.
Scans below may help.
Last edit: 3 years 6 months ago by
edb. Reason: Add more scans of carby systems.
3 years 6 months ago #228203
by n2s3
I checked it during assembly,but that’s not to say it’s not bent now. If the fuel flow and mag checks out,I guess the carb will have to come back Apart.will have to wait for the weekend before I will have a chance to work on it.keep you posted,thanks
3 years 6 months ago #228239
by edb
just edited above post to add some more scans with adjustment info and diagrams of the fuel flow thru the carb passages and jets.
3 years 6 months ago #228311
by n2s3
so finally got to the D2. Last week it had spark,this week it doesn't. ran paper thru the points,reset gap to .015 no joy. I sent mag out some years back but crs in effect,cant remember where I sent it out to. will check resource list.
also valve for pony fuel shut off now leaking at shut off valve shaft. any replacement parts available? will check for seal. Thanks Bryan
3 years 6 months ago - 3 years 6 months ago #228320
by edb
Hi,
generally the Cat pony fuel shut off valves can be repacked with the likes of a strand from a multi string type water pump pump packing or I believe a mop string rubbed/massaged full of soap works well too.
To repack :- back off the packing gland nut that is on the valve body that has the on/off shaft going thru it, dig out the old packing and determine the length of new packing to go 1 turn, plus a smidgeon more for better crush, around the shaft--cut the packing ends at 45 Degrees so as to have a better sealing overlapping joint, fit the packing gland nut and tighten as needed.
edb.
Thank you received: 663
Thank you received: 405
3 years 6 months ago #228360
by D4Jim
Modern day marvels that were not available years ago make life simple. Get some Teflon "string" from the local hardware or plumbing shop and use that. It is impervious to most any chemical and makes a great seal. Seems like the last I bought was $3 for about a 3 ft string.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
