NEW ACMOC Members Library
Thank you received: 48
3 years 6 months ago #228206
by Cat Yellow1
I'm logged in and have the same problem as the others. I'm logged in but in the Members section just see the page to become a member. I thought I had the same email for both financial and membership, but don't know how to check that.
Thank you received: 526
3 years 6 months ago - 3 years 6 months ago #228207
by gauntjoh
We are urgently trying to find out what the problems are with some members being able to access the library and some not.
I believe that this is not a problem with the library per.se. but with the underlying members and forum databases, which has been brought to light with the library implementation for members only.
I will report back when I have some news.
Last edit: 3 years 6 months ago by
gauntjoh.
Thank you received: 236
3 years 6 months ago #228211
by d2gary
I have only used 1 email and just used the members page log in and still get the same thing.
Thank you received: 324
3 years 6 months ago #228212
by Ray54
I have now seen the list of subjects in the library but could not get any to open. I clicked the 3 bars in upper right, which give a menu with 7 subjects. I then click members. I get a different screen than Yellow Cat is showing. But at the bottom left it says Technical Library , which when clicked gives a long list of subjects. I tried clicking and double clicking on subjects but nothing open.
Making headway I guess.
Thank you received: 422
3 years 6 months ago #228215
by Deebo
Make sure you scroll down after clicking on something as the content appears in a window below. Hope this helps.
3 years 6 months ago #228217
by Ray54
It worked thanks Deebo. It takes a bit of time to scroll, as the list is very long but it was there. (jumping up and down with glee, as I don't think we have emodcons on board, and I don't know enough to import any)
3 years 6 months ago - 3 years 6 months ago #228219
by Deebo
Great! The scrolling can be reduced by searching for something specific to narrow down the long list. I think there're 572 docs/videos uploaded so far with more to come once the teething troubles are ironed out.
Deebo.
3 years 6 months ago - 3 years 6 months ago #228228
by gauntjoh
If you are having difficulty accessing the new Library, please first check that your ACMOC membershiop has not expired because if it has, this would prevent you accessing the Library.
If you have a pdf file of a Caterpillar publication that you would like to submit for inclusion in the library, please email to This email address is being protected from spambots. You need JavaScript enabled to view it.
You should also use this email address if you have a problem accessing the library so that we can investigate it.
gauntjoh.
3 years 6 months ago #228242
by d2gary
I was able to get into the technical library in the members section when I logged in.
