D2 5J parts help
D2 5J parts help
3 years 9 months ago - 3 years 9 months ago #227816
by Montana16
steering clutch linkage bushings.
long story short my dad removed these bushings to have some new ones made and the machinist passed away in the process. not sure of the nomenclature on them, but thats the best i can come up with. any help with a part number or source for them would be greatly appreciated. also, if the ones from a D4 would work that would be awesome too.
thanks
‘38 5J-228
Last edit: 3 years 9 months ago by
Montana16.
3 years 9 months ago #227827
by Montana16
He found two halves that are threaded and not sure if the other sides are or not. This is what I’m after and the short threaded rods too. Thanks
‘38 5J-228
Thank you received: 240
3 years 9 months ago #227851
by Montana16
Appreciate the help. It’s been a few years since he took it apart. I guess he has the reqd parts albeit worn out. Thanks again and will try what you suggested.
‘38 5J-228
Thank you received: 810
3 years 9 months ago #227903
they are just a pin clevis with a threaded shank clevis yokes are readily available from engineering suppliers and a ht bolt could be weld on to get the threaded portion the fun bit would be getting a appropriate spring.
it also never hurts to try your cat dealer they still have listings for some parts especially if you have a parts book as they can search by part number some parts have superseded to new numbers as changes happened but the part will still fit. some parts are even still in use on later gear this is particularly so for fasteners.
Thank you received: 241
D2 5J parts help
Time to create page: 0.153 seconds
