D2 5U electric pony motor starter problems
3 years 10 months ago #225811 by D4Jim
Cub cadet had a 3 coil regulator belt driven Starter/Generator setup - kept the battery charged as would the cat setup help some to charge battery. Bob
That's right. Back in the 60's or so they had a little after thought starter / generator driven from the front mower drive as I remember. I wonder when they changed to the gear driven system.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
3 years 10 months ago #225886 by Potato Head
The new unit arrived and it looks like exactly what I need....except for one thing.  As you can see, the front of the old one had square shoulders that fit through the hole in the dash.  The new one has sloping shoulders which makes it too large to fit through the hole in the dash. Soooo ... I can either grind down the shoulders to make them square so it fits or I can cut the hole in the dash bigger.  Grinding on the generator would void any possible return while on the other hand the dozer is in the field and I don't know if I have enough extension cords to reach it to either use my grinder or saber saw.  Just another dilemma.
3 years 10 months ago #225887 by Potato Head
I have come to realize that I am not repairing an old Cat. I am buying a new one, one part at a time.
3 years 10 months ago #225888 by neil
Heh, that's right. Try swapping the front plates
3 years 10 months ago #225890 by dpendzic
from the existing stater pics it doesn't appear that the mounting boss extends thru the bulkhead? and i don't see any bolt heads on the bulkhead? any way you could bring a portable generator with you to the machine to enlarge the hole
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
3 years 10 months ago - 3 years 10 months ago #225892 by D4Jim
It looks like the mounts to the bulkhead had to have some sot of bushing between the bulkhead and the gen flange.  Just make longer bushings and move the entire gen back a 1/4 inch of so that the casting does not have to  protrude through the bulkhead.  Might have to revise or washer up the rear mout some but saves grinding or cutting a larger hole. Looks like the shaft is long enough to accommodate that and still line the belt up with the pony.
I do not see any preview on the posting site
D47U 1950 #10164
Last edit: 3 years 10 months ago by D4Jim.
3 years 10 months ago #225896 by restore49
Just take out the two long bolts and swap the end caps.
3 years 10 months ago #226006 by Potato Head
After reviewing all your input and further investigating swapping the end caps, I decided to enlarge the hole in the dash board. That accomplished, the starter was installed and it works great. Thank you all, again.
The following user(s) said Thank You: ag-mike
3 years 10 months ago #226033 by trainzkid88
 Right off hand I cannot think of any starter / generators on equipment that are belt driven. Smaller ones like lawnmowers are gear driven and electronically switched from start to gen.
this is quite common on golf carts. they have a special regulator to allow this.
many lighting plants were electric start via the generator. my Ronaldson Bros & Tippet 32 volt set is set up this way.
some of the lateset automotive engine designs are using this design too for less weight and more efficiency.
Time to create page: 0.203 seconds
