Creamy Oil in Steering Clutch control box
3 years 11 months ago #224808
by Tony Clarke
We have a rebuilt steering clutch box and pressure relief valve. The left clutch has been broken free.
Hoping to go in before the rains make it impassible to replace the steering clutch box and move the dozer up to
the ridge to swap out the blade with one in better condition.
Tony 707 338 6492
Thank you received: 999
Thank you received: 794
3 years 10 months ago #225152
water has got in some where find the leaking gasket and fix it. condensation build up can also be an issue.
3 years 10 months ago #225666
by Tony Clarke
The steering clutch box has been replaced and the steering clutches work, both right and left. Moving the dozer to the ridge to replace the blade after the rain lets up
so we can get into the property. The cable winch needs adjustment. Does anyone know how to adjust the clutch?
Tony 707 338 6492 email: This email address is being protected from spambots. You need JavaScript enabled to view it.
3 years 9 months ago #225755
what model and series is your machine without that no one can provide the correct info.
heres a tip most info required for adjustments etc are in the owners book and the servicemans reference a parts book is also helpful. dealers may not have listings for your model any more but they can still match part numbers.
Thank you received: 820
3 years 9 months ago #225783
What's the s/n of the cable control unit? Or a picture of what you have.
3 years 9 months ago #226084
by Tony Clarke
We moved the dozer up to the ridge to replace the blade. Forgot to take a picture of the cable winch. The pin on the left push arm came out and Mike backed it out for about three miles or more clearing trees out of the road as we went. Hope to get back to it in a couple of weeks after we bring the blade down from Sacramento.
Tony
