- Thank you received: 6
Oh, you bet a bad head gasket can cause all this! There were much easier ways to source your issues but I guess you have progress. You mentioned tightening bolts on the pony. If any of the head bolts were loose, that is more evidence for a gasket failure. What is also possible is straight gas got in the engine and blew the head gasket as liquid will not compress. It is notorious for bending rods but maybe Cat was smart and planned for this.Long time since my last post. Life keeps getting in the way of working on my project. I pulled the pony motor head this summer (thats no easy thing when its still on the side of the big engine). took it and had it magna fluxed and there were no cracks. I bought a spray kit to check for cracks on the top of the block and that checked out clean. I also checked behind the valve lash cover and it was completely clean in that area with no signs of coolant.
I drained the oil and it turned out to be mostly coolant. The head gasket was pretty grimy so I got a new head gasket and have it installed. Before I finish installing all of the other parts though, would a blown head gasket allow for so much coolant to go into the oil pan? I hope so because I am not certain where else it would come from and I would be left with pulling the pony motor completely.
support@acmoc.org
- Chris R
- Jason N
