Winch question
4 years 2 months ago #223145 by thumper15
Winch question was created by thumper15
Not that familiar with the different winches so I need to know if a Cat no 25 winch will bolt up to a 58 D6 9U with hydraulic lift cylinders.
4 years 2 months ago #223146 by Old Magnet
Replied by Old Magnet on topic Winch question
Along with the #25CCU you need the adapter to mount to the 9U. Also the matching pinion is preferred (but not absolutely required) to best match line speed.
4 years 2 months ago #223148 by thumper15
Replied by thumper15 on topic Winch question
I'm not sure which adapters already on it but it was off of a D6C
4 years 2 months ago #223150 by Old Magnet
Coming off a D6C it will have the correct pinion, adapter and coupling shaft to mount to a 9U. About the only difference is the D6C uses higher mount control arm levers and is designated a #126 CCU with a s/n 32E1-up. Still basically a #25 CCU.
4 years 2 months ago #223155 by thumper15
Good to know thank you for the info.
4 years 2 months ago - 4 years 2 months ago #223166 by Rome K/G
Replied by Rome K/G on topic Winch question
Ahumm Ahumm... Its called a Cable Control Unit.
Just had to correct that. lol Mag had it right though, CCU.
Last edit: 4 years 2 months ago by Rome K/G.
4 years 2 months ago #223176 by thumper15
Yeah I know its an old habit of calling it a winch. Just used to having to use simple terms with the people I work with otherwise their lost.
4 years 2 months ago #223182 by Rome K/G
True,true
4 years 2 months ago #223183 by dpendzic
Replied by dpendzic on topic Winch question
well generically it is really a winch!
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
