D4 5T fuel system
D4 5T fuel system
16 years 3 months ago #19302
by OCB
I 'm about to change the fuel filters after finding growth in my fuel tank last summer. The tank was removed last fall. I just had it steam cleaned and dried.
My question is, I'm looking for fuel filter housing drain but can't find one, the D4 7U has a drain plug next to the lower plate of the transfer pump, does this mean that the plate of the fuel transfer pump must be removed to get a complete drain on the older engine.
My 2 year old grandson is to be here next week and talks alot about tractors so I don't want to miss the opportunity if he travels 800 miles.
Thanks Clay
Thank you received: 820
16 years 3 months ago #19313
Something strange about that filter housing.....should look very similar to the "U"
models and have the drain plug at the bottom of the extension. Can you post some pictures of the upper part of the filter housing and the injection pump housing side.
Can't tell for sure from your picture but is that a brazing repair on the housing??
16 years 3 months ago #19329
by OCB
The pump/filter assembly has some major differences from the U. Primary different I see from the U maintenance manual is the bolt-on plate sizes. The first picture was the lower end of this picture.
No brazing repairs have been done, just old paint and old dirt.
With this picture you also maybe note something else alittle odd. The engine s/n 5T6802-W is setting on a older 2T frame. Thanks Clay
16 years 3 months ago #19335
That looks like the correct filter housing but the hour meter is missing and replaced with some crude looking repairs.
It appears the drain extension and plug #1A6813 is there but again it's a little tough to make out in the picture.
16 years 3 months ago #19339
by OlCatBob
OCB, I think the drain is missing... it should be behind that area where the fuel line fitting is. It's held on by two 5/16 bolts and extends down with a cap on the bottom. If it is missing, it must be closed off with a plate with 2 cap screws.
The "other" OCB
OlCatBob
16 years 3 months ago #19345
by OCB
Old Magnet you were 100% correct, there had been a little torch work as you probably suspected from the missing stud near the lower part of your diagram. The plug that goes in that hole in bonded to the casting also.
The bottom line there is no drain so I went the extra mile. I took the fuel inlet off ( I had suspected the the drain to be apart of this item) and some diesel drained. Next I took the cover 7B4289 ( above the weld) off. It drained the filter area but I didn't like like I saw. Looked to be tiny flakes of rust in the bottom. I went one step further opened up the gear pump but it was clean.
I was impressed that the pump was put togather without gaskets.
After much cleaning, flushing and cutting a couple gaskets, I'm about to seal it up.
I did cut a filter up to find clean cords. Also no water.
Another question, each filter is held by a rod. I have 2 steel and 2 fiber rods. Which might have been the original? ( My bet the Steel)
Thanks Guys
OldClayB...............
16 years 3 months ago #19346
by SJ
The pump does not have gaskets except where it bolts up to the filter housing base and the side adapter where the line screws in from the main fuel tank. Along with the gasket for mounting there is an "O" ring seal for the fuel passage on the top of the housing but that,s all the gaskets and seal there is.
16 years 3 months ago #19348
If the drain extension and plug is gone, what happened to the hole??
The fiber rods are the later style.
Very fragile so work carefully:)
16 years 3 months ago #19359
by OCB
OlCatBob
That is the rest of the story and I never suspected that to be the drain when I started. Thanks again as I'm ready for my Grandson next week.
D4 5T fuel system
