D7E serial number location
4 years 3 months ago #223037 by Mangoman
Hi everyone,
I'm hoping to help a lady determine the year of her late husband's tractor. It appears to be D7E . I am not near her so trying to give her direction to find the serial numbers. For the engine, is it left side rear of engine? What about frame? Is that going to be visible? Much thanks
4 years 3 months ago - 4 years 3 months ago #223044 by Rome K/G
Replied by Rome K/G on topic D7E serial number location
It would be above the starting engine transmission on the diesel engine block. The one on the rear left frame is probably covered by the winch. Looks like a high hp built from "66" to "69" starting with SN 48A6884-up.
Last edit: 4 years 3 months ago by Rome K/G.
The following user(s) said Thank You: Mangoman
4 years 3 months ago #223063 by Mangoman
Replied by Mangoman on topic D7E serial number location
Much appreciated Rome. I relayed the message to her.
4 years 3 months ago #223065 by edb
Replied by edb on topic D7E serial number location
Hi MM,
there is likely a S/No plate on the firewall just near where the de-compression lever is or would be if a direct electric start engine.--near the right brake pedal.
4 years 3 months ago #223066 by Rome K/G
Hi MM,
Eddie B.[/quote
Yep, there too.
4 years 3 months ago #223069 by kittyman1
-just wondering if a D7f serial number would be located in the same position...on the diesel engine block above the pony motor..?
Time to create page: 0.204 seconds
