1951 D46U Governor
1951 D46U Governor
Thank you received: 7
16 years 3 months ago #19175
by dmgrow
Can someone please post a drawing for this governor. I have a book coming but do not want to wait. Long story short is the governor is not pushing the rack open. I can push the rack by hand and the engine will run. I can feel the governor fighting to slow the engine even at an idle. I believe someone has had the governor apart while trying to get the pony pinion out. The locking tabs are unbent on the bolts that hold the bellcrank together. I believe the arm on the bellcrank may not be engaging correctly to the latch in the pump end of the governor. An old post suggest that the latch may be idle and stop???
Thanks,
Dave
Thank you received: 820
16 years 3 months ago #19193
by dmgrow
Thanks Pete
I can see how it works.
How do you adjust the idle stop bolt and what looks to be high rpms.
Dave
16 years 3 months ago #19195
Hi Dave,
Instructions:
Low idle 550 rpm
Hi idle 1525 rpm
Full load rpm 1400
Both screw - clockwise to decrease.
16 years 3 months ago #19237
by dmgrow
Pete, Thanks Again for the pics
Got the D4 to run tonight and it runs well.
Once I figured out how the governor worked it was pretty easy to spot that the hack that worked the tractor had put the damn throttle arm on backwards. It was the last of a list of everything from missing gaskets and
o rings to plugged fuel passages and a dead pony. Gonna check out the rest of the tractor tomorrow then throw the clutch and see if it rolls, steers, stops and has all of its gears. You remember my cat 12, threw the clutch and no gears. Ya never know
Dave
1951 D46U Governor
Time to create page: 0.153 seconds
