Cat Ten
16 years 4 months ago #19081 by Member2103
Cat Ten was created by Member2103
Quick questions. Am about to put the manifolds and heat box on. Do you use any gasket cement or do you put it on dry? If you use a cement, what kind is recommended? It looks like the origional nuts are brass.Should I go back with the brass nuts? Thanks, Mark
16 years 4 months ago #19082 by Catmatt
Replied by Catmatt on topic Cat Ten
olson's sells the gaskets which resist the high heat. I would use brass so you can remove the manifold in the future.
catmatt
16 years 4 months ago #19086 by Member2103
Replied by Member2103 on topic Cat Ten
I've got the gaskets. Do I use anything with them?
16 years 4 months ago #19095 by Jon
Replied by Jon on topic Cat Ten
no cement, no blue goo.... brass or stainless steel
Time to create page: 0.127 seconds
