Clutch Brake on Starter Clutch and Pinion
16 years 4 months ago #18971 by novavalleycat
Regarding my D2 J Series, I seem to have a problem slowing the pinion down and up to engage it into the flywheel. Is there an adjustment on the brake or is the adjustment only on the clutch? The clutch has a good over center snap to it. If the clutch is a little too tight, could that affect the brake?
Thanks for the help,
Jim Legge
16 years 4 months ago #18975 by Sasquatch
Replied by Sasquatch on topic Pony clutch
There is no adjustment on the pony brake that I am aware of. There was a post a while back that contained some good tips regarding this problem. Try to use the search feature to find a post titled "Pony Motor Engage". It is about a D4 but the information will also apply to your machine. It talks about different weights of oil you can try in the clutch compartment as well as some adjustments that can be made.
16 years 4 months ago #18986 by novavalleycat
I found the post you mentioned about the Pony Motor Engage, thanks so much for the help. :)
Jim Legge
Time to create page: 0.111 seconds
